Gmoccapy 3.5.1
1 year 3 weeks ago #336139 by TripleM
Replied by TripleM on topic Gmoccapy 3.5.1
Firstly, I have already implemented a solution for checking the tool table . If this seems useful for others, we could consider integrating this function directly into Gmoccapy.
I would also find it useful if there were an additional option available for each tool in the tool table—for example, a checkbox or drop-down menu for the direction of rotation (CW or CCW).  This would make it easy to determine the required direction of rotation for each tool and eliminate errors caused by incorrect rotation.
11 months 4 weeks ago #337752 by newbynobi
Replied by newbynobi on topic Gmoccapy 3.5.1
Control panel connections :
net matrix_r2c2 matrix_kb.0.key.r2c2 => halui.spindle.0.stop
net matrix_r2c1 matrix_kb.0.key.r2c1 => halui.spindle.0.forward
net matrix_r2c3 matrix_kb.0.key.r2c3 => halui.spindle.0.reverse
Why do you use the halui pin?
you could use
gmoccapy.h-button.button-2 for start as documentated here :
linuxcnc.org/docs/html/gui/gmoccapy.html..._bottom_button_lists
Norbert
The following user(s) said Thank You: maxi177
Moderators: newbynobi, HansU
Time to create page: 0.045 seconds
