Additional hardware-button for coolant
- TripleM
- Thank you received: 3
22 Oct 2025 12:50 #336874
by TripleM
Additional hardware-button for coolant was created by TripleM
Hello,
I would like to add a hardware button for cooling, for example.
Currently, my *.hal entry looks like this:
This allows me to switch the coolant on and off via the GUI.
How can I add the hardware button (push button)?
I want to be able to continue switching it on and off in the GUI and see that the cooling is switched on.
net coolant-flood <= iocontrol.0.coolant-flood => hm2_7i96s.0.7i84.0.0.output-11This allows me to switch the coolant on and off via the GUI.
- zz912
- Thank you received: 98
22 Oct 2025 13:01 #336875
by zz912
Replied by zz912 on topic Additional hardware-button for coolant
Mayby this could help
forum.linuxcnc.org/24-hal-components/53990-button-toggle
22 Oct 2025 13:20 - 22 Oct 2025 13:24 #336876
Replied by andypugh on topic Additional hardware-button for coolant
On my lathe I fitted a 3-position switch, labelled with "on - auto - off". This allows me to override the G-code if required, to either on or off.
The HAL to do this looks like this:
Possibly not the simplest way, I suppose that it could have been done with simple AND and NOT components
coolant-out = (coolant _flood OR coolant_on) AND (NOT coolant_off)
Or even LUT5.
Truth-table for LUT5
net coolant-off hm2_7i84.008a.input-25
net coolant-on hm2_7i84.008a.input-26
loadrt mux_generic config="bb4"
addf mux-gen.00 servo-thread
net coolant-off mux-gen.00.sel-bit-00
net coolant-on mux-gen.00.sel-bit-01
net coolant-flood mux-gen.00.out-bit => hm2_7i84.008a.output-08
net coolant-auto iocontrol.0.coolant-flood mux-gen.00.in-bit-00
setp mux-gen.00.in-bit-01 0
setp mux-gen.00.in-bit-02 1
setp mux-gen.00.in-bit-03 0Possibly not the simplest way, I suppose that it could have been done with simple AND and NOT components
Or even LUT5.
coolant_flood | 0 1 0 1 0 1 0 1
coolant_on | 0 0 1 1 0 0 1 1
coolant_off | 0 0 0 0 1 1 1 1
coolant_out | 0 1 1 1 0 0 0 0
LUT5 Mask = 14 (0x0E)
Last edit: 22 Oct 2025 13:24 by andypugh.
- newbynobi
- Thank you received: 394
22 Oct 2025 13:26 #336877
by newbynobi
Replied by newbynobi on topic Additional hardware-button for coolant
- TripleM
24 Oct 2025 11:46 #337041
by TripleM
Replied by TripleM on topic Additional hardware-button for coolant
The halui pin works.
nfortunately, it is currently very sensitive. If you press the button for too long, the pump switches off again or toggles between on and off.
I would need to add something that checks whether the button has been pressed again.
Does anyone have any ideas?
loadrt not names=not.coolant
loadrt and2 names=and.coolanton,and.coolantoff
addf not.coolant servo-thread
addf and.coolanton servo-thread
addf and.coolantoff servo-thread
net coolant_on not.coolant.in and.coolantoff.in0 <= halui.flood.is-on
net and1_in_1 and.coolanton.in1 and.coolantoff.in1 <= emcopanel.coolant
net and1_in_0 and.coolanton.in0 <= not.coolant.out
net and1_out and.coolanton.out => halui.flood.on
net and2_out and.coolantoff.out => halui.flood.offPlease Log in or Create an account to join the conversation.
- Thank you received: 4150
24 Oct 2025 11:56 #337042
Replied by rodw on topic Additional hardware-button for coolant
try toggle or toggle2nist components.
- juergen-home
- Thank you received: 15
25 Oct 2025 13:57 - 25 Oct 2025 14:11 #337135
by juergen-home
Replied by juergen-home on topic Additional hardware-button for coolant
Slightly changed from my gamepad pendant forum.linuxcnc.org/47-hal-examples/57498...tion-selector-switch
Maybe this works.
Maybe this works.
# Activate coolant / mist
# A single joypad button will start and stop the coolant.
# coolant on-off with toggle2nist
loadrt toggle names=tog_0 # Load N components for logical NOT operations
addf tog_0 servo-thread
loadrt toggle2nist names=tog2nist_0 # Load N components for logical NOT operations
addf tog2nist_0 servo-thread
# this toggle in front of toggle2nist is needed for regular toggle2nist.comp in 2.9.6
net net-joy-coolant-toggle tog_0.in <= input.0.btn-base3 # here is the button
net net-button-start tog2nist_0.in <= tog_0.out
net net-coolant.is-on tog2nist_0.is-on <= halui.coolant.is-on
net net-coolant-off tog2nist_0.off => halui.coolant.off
net net-coolant-on tog2nist_0.on => halui.coolant.on
Last edit: 25 Oct 2025 14:11 by juergen-home. Reason: mist --> coolant
- TripleM
27 Oct 2025 08:39 #337269
by TripleM
toogle2nist works perfectly, but I have to change the debouncetime in the componet. it will be more comfortable if the debounce-time is changed by a hal pin
loadrt toggle2nist names=toggle.coolant
addf toggle.coolant servo-thread
net coolant_is_on toggle.coolant.is-on <= halui.flood.is-on
net coolant_button toggle.coolant.in <= emcopanel.coolant
net coolant_on toggle.coolant.on => halui.flood.on
net coolant_off toggle.coolant.off => halui.flood.offcomponent toggle2nist "toggle button to nist logic";
pin in bit in "momentary button in";
pin in bit is_on "current state of device";
pin in unsigned debounce = 50 "debounce delay for 'in'-pin in cycles";
....Please Log in or Create an account to join the conversation.
Moderators: newbynobi, HansU
Time to create page: 0.241 seconds
