Yes, I lost an hour or more of my life today trying to map my network drive. It was quick and easy with Mint but XFCE's Thunar doesn't like to get involved with network drives, so you have to install gigolo it seems but even that has changed since the few how-to guides were created, just to keep you guessing. The user instructions are "commendably sparce". That's working finally.
I'm clearly going to have to run pncconfig again, if only to create some placeholder files that I can edit / replace / merge, since it seems I can't simply copy the original folders over and expect it to work.
Although I previously flashed the 5i25 with the required bitfile (link below), my particular combination of boards (5i25 / 7i76 / 7i85) doesn't appear in the pncconfig screen, so I can't configure my IO. Consequently, the generated HAL file won't be right. Is there a workaround for this?
forum.linuxcnc.org/27-driver-boards/4254...nnectors-over#208828
My plan seems to be to generate a dummy gmoccapy installation, then copy the contents of my previous INI and HAL files across, then knock over the resulting errors one by one.
The original installation had closed loop axes (X&Y) and an WHB04B-6 WMPG, which took a while to set up and debug.
