can not jog axis in Gmoccapy
3 months 3 weeks ago #347600 by Etced
Replied by Etced on topic can not jog axis in Gmoccapy
Any suggestions would be appreciated.
3 months 3 weeks ago #347602 by tommylight
This is confusing, why stepconfig?
Stepconfig is for parallel port setups, only.
3 months 3 weeks ago #347604 by Etced
Ok, that makes sense, I deleted the step config file. Currently I can jog XYZ in the pnc config "test this axis" .
Gmoccapy  jog does not work but shows movement on screen.
3 months 3 weeks ago #347624 by Aciera
Replied by Aciera on topic can not jog axis in Gmoccapy
You need to post the hal and ini files of the configuration that you are having the jogging issues with. Without those we are just poking around in the dark.
3 months 3 weeks ago #347630 by Etced
Here are the Hal and ini files.
3 months 3 weeks ago #347633 by Aciera
1. ini file is missing
2. Take the config that uses AXIS gui (which apparently works), open the ini file and in the [DISPLAY] section change 'DISPLAY = axis' to 'DISPLAY = gmoccapy'. The config should now start with gmoccapy and jogging should work using the on screen jogging buttons.
3. Looking at the header in your hal file it seems that you are using a rather old prerelease of version 2.9 '# Using LinuxCNC version: Master (2.9)'
Unless there is a particular reason for this I would recommend using a more recent release (eg 2.9.10):
github.com/LinuxCNC/linuxcnc/releases#release-v2.9.10
The following user(s) said Thank You: Etced
Moderators: newbynobi, HansU
Time to create page: 0.289 seconds
