LinuxCNC Features - a kind of NGCGUI
- Zahnrad Kopf
13 years 4 months ago #35761
by Zahnrad Kopf
Guilty, as charged. My apologies. I took his question -
Replied by Zahnrad Kopf on topic LinuxCNC Features - a kind of NGCGUI
BigJohnT wrote: No, that has nothing to do with LinuxCNC, as you know Nick only the G codes in the LinuxCNC manual are supported.
JT
in a literal sense and did not even think to wonder about LCNC specifically. That said, I'm kind of shocked that LCNC does not support G71 and the like... such a standard kind of thing... I better read some more. Wow.Are there any standard subroutines for lathe machining?
- BigJohnT
- Thank you received: 994
13 years 4 months ago #35763
by BigJohnT
Replied by BigJohnT on topic LinuxCNC Features - a kind of NGCGUI
Even G0 is not handled the same way with all controls... so never assume.
JT
JT
- Nick
- Thank you received: 11
13 years 4 months ago #35815
by Nick
Replied by Nick on topic LinuxCNC Features - a kind of NGCGUI
I've found a bug, but do not know where is it, in linuxcnc or in it's docs
The docs says:
#<_x> - Return absolute machine X coordinate. Same as #5420.
(here www.linuxcnc.org/docs/devel/html/gcode/o...ub:system-parameters )
But if we run the following code we have got (0,0) all the time. So it looks like #<_x> is relative coordinates.
Can somebody check it on other versions of linuxcnc?
My is 2.6.0-pre...
PS We have a lot of new results on Features.
A lot of interface improvements and new subroutines for lathe.
The docs says:
My is 2.6.0-pre...
G54
G10 L2 P0 X0 Z0
G1 X0 Z0
(DEBUG, xy: #<_x>, #<_y>)
G10 L2 P0 X10 Z0
G1 X0 Z0
G10 L2 P0 X20 Z0
G1 X0 Z0
M02
- BigJohnT
13 years 4 months ago #35816
by BigJohnT
I think that is only on Master and not on any branch.
JT
JT
- Nick
13 years 4 months ago #35817
by Nick
And what's about #5420-5429? Are they all the same?
- BigJohnT
13 years 4 months ago #35838
by BigJohnT
It could be a typo in Master as I doubt the numbered parameters have changed behavior from the 2.5 branch.
JT
5420-5428 - Current Position including offsets in current program units (X Y Z A B C U V W)
JT
Time to create page: 8.168 seconds
