LinuxCNC Features - a kind of NGCGUI
12 years 8 months ago #43473 by craig
Replied by craig on topic LinuxCNC Features - a kind of NGCGUI
I tried to get it working also, I could get it sort of working in the standalone mode but never embedded in Axis.
Hopefully someone will write a howto or something, this is a great add in I'd like to use.
12 years 8 months ago #43747 by Nick
Replied by Nick on topic LinuxCNC Features - a kind of NGCGUI
Hi Nick
I have been trying to get your lathe subroutines to work yet I am having a lot of command errors, could you perhaps help me through the process? I know you have insturctions on the git site, yet I am very new to linux and some of the instructions I simply don't understand. I remember you mentioning you want people to test the functions, well I have 2 industrial lathes that I would like to test these functions on. I also e-mailed you a few times through your youtube channel.
Thank you
Mike
Hi Mke,
Sorry for late answer! I've was to short of time, so I had to pause any work on Features.
What kind of errors did you get? What was the main problem?
Have you tried installing instructions from the readme.md? (here at the bottom: github.com/cnc-club/linuxcnc-features )
What version of linuxcnc are you using?
12 years 8 months ago - 12 years 8 months ago #43761 by craig
Hi Nick,
Thanks for all your hard work, I did follow those instructions but I did have trouble interpreting a few things.
but I've tried to reinstall and have gotten farther.
I'll post the error output when I get back to that PC.
I'm using the latest buildbot 2.6 on 10.04 LTS
Thanks again for the great work
Craig
Last edit: 12 years 8 months ago by craig. Reason: took another try
12 years 8 months ago #43794 by Nick
that should be fine...
12 years 8 months ago #43907 by craig
I feel a bit foolish but I have your features running perfectly, thanks very much for your great work. These routines will help me a lot.
12 years 8 months ago #43935 by craig
Humm.... I had everything working until I grabbed the latest from buildbot and now Linuxcnc wont start.
I've attached a file called crash_report.txt
Thanks in advance
The following user(s) said Thank You: Nick
Time to create page: 0.139 seconds
