- Thank you received: 124
newbynobi wrote:
I am testing a little bit with gmoccapy and I found:
configs/gmoccapy/mill.ini and mill_mm.ini
[TRAJ]
DEFAULT_LINEAR_VELOCITY=
MAX_LINEAR_VELOCITY =
must be:
[TRAJ]
DEFAULT_VELOCITY=
MAX_VELOCITY =
to avoid that strange long numbers in the Info display.TRAJ does also miss NO_FORCE_HOMING, that way you will be able to change to AUTO mode avoiding the error messages. I do not know, why it is not possible to home in your sim config.
