NativeCAM is Features renamed
10 years 3 weeks ago - 10 years 3 weeks ago #81459 by newbynobi
newbynobi wrote:
if you are in metric and you enter a user defined drill diameter, lets say 4.2 mm, it will be interpretet as inch value.
Corrected and on github
Hallo Fern,
I can not confirm that, it is still broken here.
I just pulled the newest github, merged it with my local copy and did
sudo python setup.py c sudo python setup
  • I started the my gmoccapy_NativeCAM config
  • homed all axes
  • added raw material
  • added drill change
  • selected tool 22
  • entered "select drill size" user defined 4,2
The hole is then 4,2 inch, not mm.
I checked in MDI with
(DEBUG, metric = #<_metric>)
and got
metric = 1.00000
I think the error is here (NativeCAM/configs/sim/gmoccapy/ncam_demo/ncam/scripts/ncam.ngc):
o<drillchng_001_metric> if [#<_metric> EQ 1] #<drill_diameter> = [#<drill_diameter> * 25.4] o<drillchng_001_metric> endif
Are you able to reproduce that?
Norbert
Last edit: 10 years 3 weeks ago by newbynobi. Reason: added file name of the error
10 years 3 weeks ago #81463 by FernV
Replied by FernV on topic NativeCAM is Features renamed
Looks like you saved your current work 'before' the change to drill-change.cfg
To correct :
select Utilisites->Auto-refresh to uncheck
Select Drill Change in the treeview
Add a new Drill Change
Set your parameters to the same as the first one
Delete the old Drill Change
Press on the Build button again
It will set Auto-refresh checkbox automatically
Do not forget to save your current work or you will have to redo it again next time
Fern
10 years 3 weeks ago #81464 by FernV
After you executed
have you also executed it without 'c' ?
If you redo both commands, I would like to see the output
Fern
10 years 3 weeks ago - 10 years 3 weeks ago #81465 by newbynobi
Hallo Fern,
here are the outputs:
emcmesa@gmoccapy:~/NativeCAM$ sudo python setup.py c [sudo] password for emcmesa: removed link from /usr/lib/pymodules/python2.7/gladevcp "from ncam import NCam" removed from /usr/share/pyshared/gladevcp/hal_pythonplugin.py removed link from /usr/share/pyshared/gladevcp "from ncam import NCam" removed from /usr/share/glade3/catalogs/hal_pythonplugin.py removed link from /usr/share/glade3/catalogs glade-widget-class named NCam removed from /usr/lib/pymodules/python2.7/gladevcp/hal_python.xml glade-widget-class-ref name NCam removed from /usr/lib/pymodules/python2.7/gladevcp/hal_python.xml glade-widget-class named NCam removed from /usr/share/pyshared/gladevcp/hal_python.xml glade-widget-class-ref name NCam removed from /usr/share/pyshared/gladevcp/hal_python.xml glade-widget-class named NCam removed from /usr/share/glade3/catalogs/hal_python.xml glade-widget-class-ref name NCam removed from /usr/share/glade3/catalogs/hal_python.xml emcmesa@gmoccapy:~/NativeCAM$
emcmesa@gmoccapy:~/NativeCAM$ sudo python setup.py created link in /usr/lib/pymodules/python2.7/gladevcp "from ncam import NCam" added to /usr/share/pyshared/gladevcp/hal_pythonplugin.py created link in /usr/share/pyshared/gladevcp "from ncam import NCam" added to /usr/share/glade3/catalogs/hal_pythonplugin.py created link in /usr/share/glade3/catalogs glade-widget-class named NCam added to /usr/lib/pymodules/python2.7/gladevcp/hal_python.xml glade-widget-class-ref named NCam added to /usr/lib/pymodules/python2.7/gladevcp/hal_python.xml glade-widget-class named NCam added to /usr/share/pyshared/gladevcp/hal_python.xml glade-widget-class-ref named NCam added to /usr/share/pyshared/gladevcp/hal_python.xml glade-widget-class named NCam added to /usr/share/glade3/catalogs/hal_python.xml glade-widget-class-ref named NCam added to /usr/share/glade3/catalogs/hal_python.xml emcmesa@gmoccapy:~/NativeCAM$
I followed your instructions point by point, but the behavior does not change.
It is also the same if I open a new project and add there the raw material, drill change and single drill.
If I enter user defined, it is a inch value, so I am not able to make a base bore for M5 with must be 4,2 mm.
very strange, as my ncam.ngc has changed!
and if i try now to make new project, and want to add raw material nothing happen.
I am not able to add any feature any more. If I close linuxcnc and restart it, I get my old work and are able to edit every part.
Norbert
10 years 3 weeks ago - 10 years 3 weeks ago #81466 by eFalegname
Hi Fern,
to be sure I redid the whole procedure, now my LinuxCNC starts, but I can not maximize the window, it does not fit on the screen properly
ef@pl ~ $ cd /home/ef/linuxcnc/configs/NativeCAM/ ef@pl ~/linuxcnc/configs/NativeCAM $ sudo python setup.py c[sudo] password for ef: "from ncam import NCam" removed from /usr/lib/python2.7/dist-packages/gladevcp/hal_pythonplugin.py removed link from /usr/lib/python2.7/dist-packages/gladevcp glade-widget-class named NCam removed from /usr/share/glade3/catalogs/hal_python.xml glade-widget-class-ref name NCam removed from /usr/share/glade3/catalogs/hal_python.xml ef@pl ~/linuxcnc/configs/NativeCAM $ sudo python setup.py "from ncam import NCam" added to /usr/lib/python2.7/dist-packages/gladevcp/hal_pythonplugin.py created link in /usr/lib/python2.7/dist-packages/gladevcp glade-widget-class named NCam removed from /usr/share/glade3/catalogs/hal_python.xml ef@pl ~/linuxcnc/configs/NativeCAM $ cd ef@pl ~ $ linuxcnc /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/mill-mm.ini LINUXCNC - 2.8.0-pre1-2638-g7be62e6 Machine configuration directory is '/home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo' Machine configuration file is 'mill-mm.ini' Starting LinuxCNC... Found file(REL): ./core_sim.hal Note: Using POSIX non-realtime Found file(REL): ./sim_spindle_encoder.hal Found file(REL): ./axis_manualtoolchange.hal Found file(REL): ./simulated_home.hal note: MAXV max: 53.340 units/sec 3200.400 units/min note: LJOG max: 53.340 units/sec 3200.400 units/min note: LJOG default: 30.480 units/sec 1828.800 units/min note: jog_order='XYZ' note: jog_invert=set([]) task: main loop took 0.011481 seconds NativeCAM info: inifile = /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/mill-mm.ini SYS_DIR = /home/ef/linuxcnc/configs/NativeCAM NCAM_DIR = /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/ncam program = /usr/lib/python2.7/dist-packages/gladevcp/ncam.py real path = /home/ef/linuxcnc/configs/NativeCAM/ncam.py Created 2 files in /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/ncam/catalogs Created 49 files in /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/ncam/cfg Created 45 files in /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib Created 151 files in /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/ncam/graphics Created 3 files in /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/ncam/xml [RS274NGC]SUBROUTINE_PATH = ncam/lib/mill:ncam/lib/utilities SUBROUTINE_PATH[0] (realpath) = /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib/mill SUBROUTINE_PATH[1] (realpath) = /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/ncam/lib/utilities Using standard menu.xml, no menu-custom.xml found Can not find file quick_access.lst Can not find file current_work.xml Can not find file def_template.xml <class 'Xlib.protocol.request.QueryExtension'> <class 'Xlib.protocol.request.QueryExtension'> task: main loop took 0.014469 seconds task: main loop took 0.109366 seconds task: main loop took 0.013258 seconds task: main loop took 0.011499 seconds task: main loop took 0.010251 seconds task: main loop took 0.015063 seconds
image missing http://i.imgur.com/Tpfao9B.jpg
Last edit: 10 years 3 weeks ago by eFalegname.
10 years 3 weeks ago - 10 years 3 weeks ago #81467 by newbynobi
Have you tried to reduce the window with in preferences of NativeCAM ?
It is well explained in the basic you tube videos.
Norbert
Time to create page: 0.327 seconds
