NativeCam raspberry Pi 4
9 years 4 months ago - 9 years 4 months ago #94274 by FernV
LinuxCNC has released version 2.7.9 that fully support applications like NativeCAM as deb package.
If your version is updated to 2.7.9, you should now change your setup to use the deb with automatic updates
Download this script that will do everything for you, setting up your repository and install NativeCAM
File Name: ncam_debsetup.txt
File Size:5.14 KB
Open a terminal where it is downloaded (do not rename this file)
Copy this command and run :
sudo bash ncam_debsetup.txt
That's all there is, run LinuxCNC as you did before
You can now delete old ~/NativeCAM directory
Fern
Last edit: 9 years 4 months ago by FernV. Reason: Replaced commands with a single sh script
9 years 4 months ago #94285 by gmouer
Hi Fern,
I will follow your instructions this morning when I go into the shop. I do have a question: For future automatic deb updates, do I have to add that location to my repository lists in Debian? I am not very proficient with linux but it appears NativeCam code is stored at a different repository url than linuxcnc and wouldn't be found without adding it to the repository list.
Thanks.
George
9 years 4 months ago #94292 by grump
Damn, now the Ncam tab has gone blank again.
9 years 4 months ago #94294 by FernV
grump wrote: ...the Ncam tab has gone blank again.
Change directory to where your inifile is and restore your inifile backup.
Then : ncam -t -i (inifilename)
This is the fastest way to re-initialize it.
ncam.ui is in a new directory and it should be reflected in your inifile
Fern
P.S. Your repository has been updated
9 years 4 months ago #94296 by grump
I didn't want to do this just when it was all sorted and working great after all the aggro we had to get it working.
Just a note that I am still on previous version after updating everything, tell me it's me doing it wrong again.
9 years 4 months ago - 9 years 4 months ago #94301 by FernV
Not a good idea to revert to pre-release version but if you really want to do it, be aware that nondeb_setup.py is not part of NativeCAM github anymore and I will not make it possible in the future to use as a non-deb.
You make me giving you support much more complicated.
First, issue the same command : ./nondeb_setup.py
Then I need to see your inifile
Fern
Time to create page: 0.390 seconds
