NativeCam raspberry Pi 4
14 Jun 2017 02:22 #94497 by joey81
Replied by joey81 on topic Use NativeCAM as a deb package now
Hi FernV,
I have 2.7.8 on Debian Wheezy and just got it updated to 2.7.9.
I get this error when I run your setup script:
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...curl: (7) Failed to connect to packagecloud.io port 443: Network is unreachable
  • FernV
  • FernV's Avatar Topic Author
  • Platinum Member
  • Platinum Member
14 Jun 2017 03:11 #94498 by FernV
Replied by FernV on topic Use NativeCAM as a deb package now
...Failed to connect to packagecloud.io port 443: Network is unreachable
Try to open this page :
https://packagecloud.io/FernV/NativeCAM/install
I think it is not a NativeCAM problem but if it does open, re-run the script.
Fern
14 Jun 2017 03:29 #94499 by joey81
I managed to successfully install by doing the following:
- manually download config_file.list to /etc/apt/sources.list.d/FernV_NativeCAM.list
- edit ncam_debsetup.txt to skip the part that gets the error
27 Jun 2017 08:27 #95026 by tecno
Replied by tecno on topic Use NativeCAM as a deb package now
This is what I get when installing nativeCAM
sudo bash ncam_debsetup.txt
Detected operating system as debian/stretch.
Checking for curl...
Detected curl...
Running apt-get update... done.
Installing debian-archive-keyring which is needed for installing
apt-transport-https on many Debian systems.
Installing apt-transport-https... done.
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...done.
Importing packagecloud gpg key... done.
The repository is setup! Installing NativeCAM... done.
But where is it and how do I start NativeCAM??
27 Jun 2017 09:08 - 27 Jun 2017 09:11 #95028 by eFalegname
Replied by eFalegname on topic Use NativeCAM as a deb package now
Hi Fern,
I updated my linuxcnc to the master version 2.8 on debian 9. The NativeCam install runs flawlessly, but I don't know how I do start it...
Cheers
Floris
Last edit: 27 Jun 2017 09:11 by eFalegname.
  • FernV
  • Platinum Member
  • Platinum Member
27 Jun 2017 12:35 #95039 by FernV
...Detected operating system as debian/stretch.
Hi
You have the same situation as here
forum.linuxcnc.org/40-subroutines-and-ng...e-now?start=10#94463
read how Norbert solved it
forum.linuxcnc.org/40-subroutines-and-ng...e-now?start=10#94471
I also uploaded a deb for debian/stretch
You can simply re-run the script
Fern
  • FernV
  • Platinum Member
  • Platinum Member
27 Jun 2017 12:49 #95042 by FernV
Hi Floris,
Run first :
$ linuxcnc_var all
If the result has :
LINUXCNC_AUX_GLADEVCP=/usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES=/usr/share/linuxcnc/aux_examples
then your version can use the deb.
In any directory type :
$ ncam -h
Fern
27 Jun 2017 13:03 #95044 by tecno
Hi Fern,
I did run the script now = took very long time before DONE but still I see no NativeCam.
Where are files installed?
/Bengt
27 Jun 2017 13:26 - 27 Jun 2017 13:35 #95046 by eFalegname
I'm in the same situation as tecno, too much installation time and nothing about Native Cam.
Last edit: 27 Jun 2017 13:35 by eFalegname.
  • FernV
  • Platinum Member
  • Platinum Member
27 Jun 2017 13:37 #95049 by FernV
Have you done this
$ ncam -h
Fern
The following user(s) said Thank You: tecno
Time to create page: 2.281 seconds
