NativeCam raspberry Pi 4
  • FernV
  • FernV's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Nov 2017 13:50 #102061 by FernV
Replied by FernV on topic Use NativeCAM as a deb package now
.. when I edit the tool.lib in the LinuxCNC side the complete program stops working, if I go into an editor and remove the new tool it works again.
Can you post your (not working) tool.lib ?
It may be something simple like the subroutine path that I have edited to get my buttons working
Please explain and post related stuff
Regards
Fern
20 Nov 2017 20:29 #102103 by lucky phil
Replied by lucky phil on topic Use NativeCAM as a deb package now
Hi Fern
The last entry in the tool.tbl is the one that I added and is causing the problem, if I remove it using an editor aal is fine.
I added ":/home/philip/linuxcnc/configs/Maximus/ROUTINES" to the end of the SUBROUTINE PATH to get my side panel buttons to work aswell.
I renamed tool.tbl to tool.txt as I could not upload it.
Philip
  • FernV
  • Platinum Member
  • Platinum Member
20 Nov 2017 20:53 #102104 by FernV
You may have too many tools.
Accordind with this documentation the maximum is 56
wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolTable
I do not know if the last empty line count
Fern
20 Nov 2017 21:10 #102106 by rene-dev
Replied by rene-dev on topic Use NativeCAM as a deb package now
Hi, im playing with nativecam in lathe mode, and so far everything works.
however, sometimes I get this error, and can only fix it by restarting linuxcnc.
any ideas?
Rene
  • FernV
  • Platinum Member
  • Platinum Member
20 Nov 2017 21:23 #102107 by FernV
Hi René
G96 <D-> S- (Constant Surface Speed)
G97 (RPM Mode)
Open /home/emc/nativecam/scripts/ncam.ngc and find G96 and see if S follows this and it should not be 0. If 0 then in Tool Change see what speed you have entered for Constant Surface
(I am not near my computer and this was answered from memory, it may be other name)
Fern
21 Nov 2017 09:10 #102125 by lucky phil
Hi Fern
I have tidied up my tool library and removed some, now it works.
Thankyou
27 Nov 2017 21:06 #102402 by Geshka
Replied by Geshka on topic Use NativeCAM as a deb package now
Hello Fern.
I installed LinuxCNC and nativeCAM as you recommended at the beginning.
Now I have standalone nativeCAM working , but when j I am trying to start LinuxCNC with embedded ncam I've got empty ncam tab and following test - can you please, suggest how to fix it
gyakubov@LinuxCNC:~$ linuxcnc ~/Desktop/my-mill/my-mill.ini
LINUXCNC - 2.7.0
Machine configuration directory is '/home/gyakubov/Desktop/my-mill'
Machine configuration file is 'my-mill.ini'
Starting LinuxCNC...
Found file(REL): ./my-mill.hal
Found file(REL): ./custom.hal
(gladevcp:7366): libglade-WARNING **: Expected <glade-interface>. Got <interface>.
(gladevcp:7366): libglade-WARNING **: did not finish in PARSER_FINISH state
**** GLADE VCP ERROR: With xml file: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.ui : could not create GladeXML object
  • FernV
  • Platinum Member
  • Platinum Member
27 Nov 2017 21:16 #102403 by FernV
If you use many tabs, NativeCAM has almost certainly replaced one of your command.
Go through this short thread and you will find your solution. If not let me know.
Regards
Fern
27 Nov 2017 23:33 #102411 by Geshka
Hi Fern.
Somebody indeed, asked similar question, but I did not found related answer, sorry again if I missed that - I did searched trough several times.
P.S. I am not using any tabs - it is fresh install of Debian/LinuxCNC
Appreciate your help.
  • FernV
  • Platinum Member
  • Platinum Member
28 Nov 2017 02:08 - 28 Nov 2017 02:10 #102421 by FernV
Post here your inifile and the output of the terminal window.
Have you used the deb package ?
The old method will not work and is not supported anymore, have you used it before ?
Fern
Last edit: 28 Nov 2017 02:10 by FernV.
Time to create page: 0.491 seconds
