NCam : Can not enter float values after update to latest deb
08 Sep 2017 13:31 #98684 by eFalegname
08 Sep 2017 14:50 #98691 by FernV
You should be able to update now
I used it for days without issue, let me know if you do have some
Fern
08 Sep 2017 16:55 #98703 by eFalegname
Fern and Norbert
all it's ok, now the calculator works fine.
Thank you!
  • newbynobi
  • newbynobi's Avatar Topic Author
  • Platinum Member
  • Platinum Member
12 Sep 2017 08:38 #98866 by newbynobi
Hallo Fern,
you changes did solve the problem of the decimal separator with German Localization, but the "Pi" problem is still there.
If I push Pi, the display of the calculator shows Pi, if I then press "=" I get 314159265359,000
I I press enter, the value is concerted to be "25399997,460"
But I expected to get something like 3.14159....
That happens, because math(Pi) does return a dot separated value, nevertheless what localization you have.
That is why i changed the conversion to be
temp = temp.replace('Pi', str(math.pi).replace(".",decimal_point))
Norbert
  • newbynobi
  • Platinum Member
  • Platinum Member
12 Sep 2017 08:38 #98868 by newbynobi
Hallo Floris,
have you tried the Pi part?
Norbert
12 Sep 2017 10:27 - 12 Sep 2017 10:41 #98873 by FernV
This is really strange because even on your pc locale.atof('2.5') returned 2.5 the right value.
It will be changed tonight.
Fern
Last edit: 12 Sep 2017 10:41 by FernV.
12 Sep 2017 13:27 - 12 Sep 2017 13:29 #98888 by FernV
Hi Norbert,
I was finally able to reproduce your issue. I had to use :
export LANG='de_DE'
run the test and locale.atof('2.5') finally resulted in 25.000
de_DE and fr_CA both use ',' for decimal separator and this issue never occured on my pc's as
locale.atof('2.5') always resulted in 2.500
Fern
Last edit: 12 Sep 2017 13:29 by FernV.
