Milling a pocket is not a continuous move?
- Longbow
10 Apr 2018 06:27 #108711
by Longbow
Milling a pocket is not a continuous move? was created by Longbow
Hi all!
I will try to explain my problem briefly:
When milling a pocket the path is not continuous. The CNC machine stops at some points. I observed that when milling a circle shaped pocket it stops for 3 times during a circle instead of using a continuous motion through the entire circle.
It is the same with other milling options: inside normal / outside normal / on the line
I tried with 100% ramp-down but it still pauses.
I tried with the same feed speeds for vertical and horizontal motion but still pauses.
I tried playing with the G64 command but it still pauses.
For smaller endmills this pausing during milling could be fatal.
Otherwise I really like the nativeCAM package. It makes 90% of the shop tasks a breeze. Bravo!
10 Apr 2018 15:12 #108750
Replied by andypugh on topic Milling a pocket is not a continuous move?
Are you sure that you are not in exact-stop mode?
- FernV
- Thank you received: 124
10 Apr 2018 15:42 #108754
by FernV
Replied by FernV on topic Milling a pocket is not a continuous move?
Hi Andy,
Pockets gcode are being re-coded to use only spiral mode.
Can you explain exact-stop mode ? I never heard of it before
Regards
Fern
Regards
Fern
10 Apr 2018 15:51 #108756
G61.1 is exact stop mode:
linuxcnc.org/docs/2.7/html/user/user-con...html#_path_following
The following user(s) said Thank You: FernV
- Thank you received: 7478
10 Apr 2018 23:13 #108775
Replied by tommylight on topic Milling a pocket is not a continuous move?
Most probably to low acceleration, so it slows down on every cut line or radius.
- Longbow
11 Apr 2018 08:38 #108795
by Longbow
Replied by Longbow on topic Milling a pocket is not a continuous move?
I tried with G64 P1.0 and still pauses during a move.
My acceleration is set to 300mm /s which I think is enough because when I do a separate CAM program using helix, it will not pause.
- Longbow
11 Apr 2018 08:41 #108796
by Longbow
Also, I observed that the last cut goes smooth without pause the entire circle. That is the cut when it is on the final cutting depth.
So there must be a problem during ramp-down?
11 Apr 2018 10:55 #108802
Perhaps your Z axis has lower accel than X and Y?
- fc60
- Thank you received: 9
11 Apr 2018 16:13 #108822
by fc60
Replied by fc60 on topic Milling a pocket is not a continuous move?
Greetings,
Try G64 P0.001
P1.0 seems rather coarse.
Cheers,
Dave
Try G64 P0.001
Cheers,
Dave
- Longbow
12 Apr 2018 08:30 - 12 Apr 2018 08:35 #108871
by Longbow
@andypugh:
All 3 axis have the same acceleration rate. Even if it wasn't so, It should only deaccelerate, not pause aka stop during the move?
Does your machine work without pausing?
@fc60:
I think that the default setting in nativeCAM is G64 P0.005
I also tried P0.001 but it's the same. So I went the other way to see if any change happens but it's like I did not change a thing.
I wonder if the problem lies in the way that nativeCAM builds up the program code (g-code) subrutines?
@fc60:
Last edit: 12 Apr 2018 08:35 by Longbow.
Time to create page: 0.251 seconds
