PathPilot PC Hardware
10 years 6 months ago #73811 by smgvbest
Replied by smgvbest on topic PathPilot PC Hardware
I would add to the whole pathpilot video question
A looking at the Pathpilot PC shows it using integrated graphics. now it may not be Intel but it is integrated
you can see this in the pathpilot upgrade doc.
The following user(s) said Thank You: tomdchi
10 years 6 months ago #73814 by tomdchi
Replied by tomdchi on topic PathPilot PC Hardware
Ah! I found the following: TD10342_PathPilot_Upgrade_Kit_0415A.pdf
on Tormach's website. According to that, #1 in your clipped image is the motherboard's parallel port, which is not used with PathPilot, and #2 is the Mesa card's port.
But as you point out: they're clearly using the integrated graphics off the motherboard! Thanks!
10 years 6 months ago #73877 by cncnoob1979
Replied by cncnoob1979 on topic PathPilot PC Hardware
This combo I am currently running PP on. This set-up has turned out wonderful for me and latency around 5-7.
I listed the components in my thread below. Hope you have fun getting everything going!
forum.linuxcnc.org/forum/30-cnc-machines...ofit?start=210#72061
10 years 6 months ago #73880 by tomdchi
cncnoob1979 - thanks! It's good to see I'm on the right track. I see you used a 7i77 BOB - I"m planning on a 7i76, which obviously has some differences, but I may bug you with some questions when I get to that. Cheers!
10 years 6 months ago #73910 by cncbasher
Replied by cncbasher on topic PathPilot PC Hardware
7i76 is for Stepper based Machines , the 7I77 is the equivalent but for Servo's , they both use the same 5i25 interface as far as the PC is concerned.
Time to create page: 0.287 seconds
