Why Fight it?
9 years 1 month ago #99118 by gryphon68
Replied by gryphon68 on topic Why Fight it?
smgvbest, are you talking about a 7i76 board? If I understand the OP correctly, he is not planning to use one. He plans to connect a 5i25/6i25 directly to the Tormach Control Board which will out put Step/Direction and has other I/O for limit switches and VFD Spindle Control (but not encoder input).
9 years 1 month ago #99440 by andypugh
Replied by andypugh on topic Why Fight it?
gryphon68 wrote: smgvbest, are you talking about a 7i76 board? If I understand the OP correctly, he is not planning to use one. He plans to connect a 5i25/6i25 directly to the Tormach Control Board which will out put Step/Direction and has other I/O for limit switches and VFD Spindle Control (but not encoder input).
Even then, the 5i25 has a second header which could easily have an encoder counter on it.
9 years 1 month ago #99605 by smgvbest
Replied by smgvbest on topic Why Fight it?
Yes, my bad. my head is on the lathe more than the mill and I was thinking lathe.
But as mentioned by andy, one could use the other port on the mesa and a BOB to add the encoder.
Time to create page: 0.049 seconds
