Why Fight it?
9 years 2 months ago - 9 years 2 months ago #97157 by CBRPER
Replied by CBRPER on topic Why Fight it?
Last edit: 9 years 2 months ago by CBRPER.
9 years 2 months ago #97413 by smgvbest
Replied by smgvbest on topic Why Fight it?
Thanks for the pics.
there is only one component I can't make out but I'm sure it's a 12V regulator and that's the one near TP9. the black rectangular part. Otherwise this is a basic BOB with some code running on the PIC/AVR (i'll bet on a AVR for aurdinio) but could be wrong. code would mainly be handling the Limit switch -> freq conversion and the ATC maybe.
if that's the case you dont' need to reproduce the whole board. just the Limit switch and ATC code.
9 years 2 months ago #97676 by CBRPER
If you want I can email you some nice hi res pic's. When I try to upload them here they have issues. I can email then to you if you like. I've sent one set to a guy already.
9 years 1 month ago #99095 by gryphon68
Replied by gryphon68 on topic Why Fight it?
Are you planning to drop the Rigid Tapping feature that the Fadal most likely had before it's controller quit?
The Tormach BOB is probably not capable of handling a spindle encoder pulse.
9 years 1 month ago - 9 years 1 month ago #99100 by CBRPER
The Fadal is a TRM mill.
It has color LCD monitor and from what I understand the latest version of there control before the were no longer made.
It has a 8gig memory expansion card as well.
The deal with a pro type control is everything you touch for it is high as h*ll. Just to add a fourth axes is stupid money. I don't want to be shackled to a couple of part vendors that are licking there chops every time I need to upgrade or fix the control.
My plan is to get PathPilot up and going test it on my Tormach to ensure it works properly and get it setup running Clear Path motors. I'm going to fix the Fadal contol and part it out to offset the cost of this build.
The ridge tap mean nothing to me. I tap with a floating taping and I do just fine.
Last edit: 9 years 1 month ago by CBRPER.
9 years 1 month ago #99102 by smgvbest
the spindle encoder goes directly to the mesa board. the BOB doesnt' interpret it. just passes it thru so there should no concern here.
Time to create page: 0.278 seconds
