Adding real time modules to pathpilot possible?
- DaOne
- Thank you received: 6
23 Oct 2017 22:05 #100700
by DaOne
Adding real time modules to pathpilot possible? was created by DaOne
I would like to add a couple of modules such as "mux4.ko" to pathpilot. How would I go about getting or creating these files to work with pathpilot?
- smgvbest
- Thank you received: 51
24 Oct 2017 00:13 #100707
by smgvbest
Replied by smgvbest on topic Adding real time modules to pathpilot possible?
2 ways i can think of since pp is based on 2.6.0~pre you can find a CD for that and use the modules from it or build your own as needed.
second is get the PP source disk from Tormach (cost me $10) and make a dev environment from it so get modules.
thats what I did for the some modbus drivers
- DaOne
24 Oct 2017 16:36 #100752
by DaOne
Replied by DaOne on topic Adding real time modules to pathpilot possible?
I tried doing this with 2.6.13 with classic ladder following this guide...
forum.linuxcnc.org/pathpilot/31483-classicladder-in-pathpilot
No joy. Is there a specific version required?
- smgvbest
24 Oct 2017 16:42 #100753
by smgvbest
Yes, PP was built with 2.6.0-pre I mentioned above. realtime modules as I understand are linked to kernal and rtia they are built for
FWIW - I found 2.6.0-pre searching with google
- DaOne
24 Oct 2017 16:54 #100754
by DaOne
Sorry I am very green when it comes to linux. I found the 2.5 live dvd with lucid 10.04. I could not find a 2.6.0 - pre version. I installed 2.5 but I am having troubles updating that to 2.6.0 - pre. I updated all the sources on the install so it will update via the package manager. 2.6.13 is the version it gives me. I assume there is a way to upgrade to the specific version via the terminal. I am having trouble locating that. Maybe you can help? Sorry I am learning
- DaOne
24 Oct 2017 17:14 #100756
by DaOne
Everything I have found points me here...
www.linuxcnc.org/docs/2.6/html/common/Updating_LinuxCNC.html
That only allows the latest 2.6 from what I can tell?
24 Oct 2017 23:45 #100766
Does Pathpilot have the "halcompile" or "comp" (we changed the name) command? If it does then it should be relatively easy.
Replied by andypugh on topic Adding real time modules to pathpilot possible?
- DaOne
25 Oct 2017 00:06 #100767
by DaOne
Is this where I would look?
operator@tormachpcnc:~$ halcompile
halcompile: command not found
operator@tormachpcnc:~$ comp
The program 'comp' can be found in the following packages:
* mailutils-mh
* nmh
Try: sudo apt-get install <selected package>
operator@tormachpcnc:~$ Is this where I would look?
25 Oct 2017 00:21 #100769
No. You don't have it.
(the unhelpful message about "comp" is the reason the name was changed to "halcompile")
Is there enough shinyness in Pathpilot to make it worth all this pain?
- DaOne
25 Oct 2017 00:47 #100770
by DaOne
Well, I have a 9x20 lathe I converted over from manual to Mach3 to pathpilot. (so this is a big step up) I have everything working but my MPG and my physical cycle start / feed hold buttons. I really need mux4 for the MPG. The buttons I will do in hal with what I have to work with. I have used classic ladder before and its a great addition for when I add a tool changer. Now... The reason I am in love with pathpilot is the ease of use. Its straight forward. I have 2 sons that want to learn to use it and I feel with this interface I can get them up to speed fast. I love to learn as well and this has been a big learning experience. I figured out how to get my old elo touch screen going that was serial by turning on the serial ports they turned off and editing a few files to make it all work. Even the calibrate feature in pathpilot works. So I am way too close to give up now
Also someone else reported that classic ladder is working so I wanna get it working on this machine as well for when the time comes. Any help is much appreciated.
Time to create page: 0.107 seconds
