- User Interfaces
- Other User Interfaces
- PathPilot
- PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
- cncnoob1979
- Thank you received: 75
02 Mar 2018 21:18 #106864
by cncnoob1979
Replied by cncnoob1979 on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
I mean I want to pull the GUI from pp and use it on a normal install of linuxcnc.
Just keeping the GUI design and capabilities. Create another axis;gmoccapy or gscreen.
- dinkata
13 Apr 2018 13:08 #108942
by dinkata
Replied by dinkata on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
please tell how to make launcher in PathPilot 2. for non Tormach machine 5i25+7i77 ?
Sim work ctrl+alt+s .
- DaOne
- Thank you received: 6
15 Apr 2018 07:01 #109058
by DaOne
Create a shortcut and use this as the command...
Replied by DaOne on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
mate-terminal -x bash -c "~/operator_login"
The following user(s) said Thank You: dinkata
- dinkata
15 Apr 2018 08:07 #109059
by dinkata
Thanks ,
on startup i choise sim ,
make launcher - ok , work !
How to change from sim to my config 5i25+7i77 ?
my config 5i25+7i77 work in PathPilot 1.9.13 .
- Stigoe
- Thank you received: 8
15 Apr 2018 11:02 #109061
by Stigoe
Replied by Stigoe on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
Hi.
I for one would like a how-to on how to add full functionality to PathPilot. I'm currently converting my benchtop lathe to CNC with PathPilot and I need to be able to compile toggle2nist to be able to add physical buttons. Or do anyone have a working toggle2nist they would share? I'm currently running 2.0.2.
Br,
Stig
Br,
Stig
- Thank you received: 4138
15 Apr 2018 12:32 #109065
Replied by rodw on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
toggle2nist is a standard component.
try typing man toggle2nist and you should get the manual page.
linuxcnc.org/docs/html/man/man9/toggle2nist.9.html
- Stigoe
15 Apr 2018 12:47 #109068
by Stigoe
In LinuxCNC it's probably correct, in PathPilot it's not. PathPilot comes with a rather crippled version of LinuxCNC, especially PP2.
15 Apr 2018 22:28 #109103
Well just go to LinuxCNC on github and pull down the comp file and type halcompile --install toggle2nist.comp
Check the docs, you may need to install linuxcnc-dev first.
- smgvbest
- Thank you received: 51
15 Apr 2018 22:51 #109104
by smgvbest
Replied by smgvbest on topic PathPilot 2 How to use/enable FULL LinuxCNC capabilities.
To enable full functionality in PP you need to code the GUI to do so not the other way around.
The underlying LinuxCNC has only the functionality Tormach wants to support for their machines which from a product support point of view is the correct decision. They had no desire to become a linuxcnc support group and deal with all the varied things you could do in LinuxCNC and screw up your Tormach and expect them to fix it.
Adding a full LimuxCNC under PP is the easy part. there's only a few tormach specific modules to worry about.
The problem is you have to add any/all LinuxCNC functionality you want to the PP GUI, that's the hard part.
The easier approach is to ask what do you want to add then you look at how to add it instead of trying to do everything.
- DaOne
16 Apr 2018 00:24 #109108
by DaOne
I tried this. As soon as I installed the full linuxcnc package PP stopped working. I think the kernel or something gets changed. Kinda over my head.
- User Interfaces
- PathPilot
Time to create page: 0.124 seconds
