PP 7i92/C11G problem
7 years 4 months ago #136934 by Techsavvy34
Replied by Techsavvy34 on topic PP 7i92/C11G problem
If you could post your 2.2.2 files that would be great.
7 years 4 months ago #136938 by crowloy
Replied by crowloy on topic PP 7i92/C11G problem
here you go.
File Name: pp-2.2.2_2...14-2.tgz
File Size:8.82 KB
7 years 4 months ago #137221 by Techsavvy34
Has anyone had problems with pathpilot connecting to the 7i92? When I load pathpilot it says trying to connect to machine control board.
What should the W5 and W6 jumpers be set to? Also could it be because I'm just powering the board without anything else connected to it. I just wanted to update pathpilot.
7 years 4 months ago #137222 by PCW
Replied by PCW on topic PP 7i92/C11G problem
Pretty sure Tormach uses 10.10.10.10 so
W5 Down
W6 Up
7 years 4 months ago - 7 years 4 months ago #137240 by Techsavvy34
Yeah the command line console says its looking for 10.10.10.10. If I pull up my network conne tions it shows eth0 as 10.10.10.9
I tried it W5 down and W6 up still not working.
I am using a USB cable connected to my laptop with one end cut off and the power and ground plugged into the mesa. Could it be that it's not getting enough power?
Last edit: 7 years 4 months ago by Techsavvy34.
7 years 4 months ago #137248 by smgvbest
Replied by smgvbest on topic PP 7i92/C11G problem
The way I understand USB is by default an unconfigured port will deliver up to 100mA for USB2 and 150mA for USB3, that should be enough for a unloaded 7i92.
if your driving some load off the IO pins then it won't be enough.
i really would try using a 5v 2amp wall wart as that's the max power the 7i92 says it will consume depending on loads
A raspberry pie power wart will do it.
Time to create page: 0.352 seconds
