Best video card for pathPilot
- Vmax549
- Thank you received: 28
02 Jul 2019 16:37 #138411
by Vmax549
Replied by Vmax549 on topic Best video card for pathPilot
You are correct. DO you use teh minimum spec PC ? When comparring a bare minimum spec verses a performance spec which would you choose.
I was hoping that someone had already done teh investigation on a high end PC spec and what would be the point of no returns say 1gb memory verses 4gb memory. Onboard graphics verses Video card with 4gb memory.
I do knw that poor video performance effects toolpath drawing.
Just a thought, (
TP
Just a thought, (
- Vmax549
02 Jul 2019 21:28 #138440
by Vmax549
Heard back from Tormach today on teh subject.
"" The current PathPilot computer is a 64 Bit CPU running Linux 17.3 Mint. Dual core is plenty. You won't need any more than on board video, and 4 GB of memory will work fine.""
FAR cry from teh LinuxCNC recomendations.
So at least NOW we know the rest of the story
TP
- smgvbest
- Thank you received: 51
02 Jul 2019 23:29 #138458
by smgvbest
Replied by smgvbest on topic Best video card for pathPilot
The answer you got from tormach was posted several times in this forum, including by myself.. a search would of turned that up. but I for one did not understand what you where really after, you do not need a i7 3.4GHZ with 32G of ram for PP, most of that will go to waist, Tormach has stated that and posted in this forum.
Tormach also recently fixed a issue with rendering in PP and added options to handle different rendering options. see their release notes for details. they also did a youtube video on it.
The subject was best video card which is why the comment about if it works on LinuxCNC it will work on PP, Tormach uses the Intel HD video on thier PCs, no special card as they stated. The memory went from 2-3GB in PP V1 due to being 32bit up to 4Gb in V2 because they went 64bit and could use more. the main purpose of memory is to handle larger GCODE files not for performance.
- smgvbest
02 Jul 2019 23:44 #138462
by smgvbest
BTW, 2.9? current is 2.7.14 and dev is at 2.8
Where is 2.9 you're referring too?
And FWIW, this is a Pathpilot Discussion forum, coming in and trying to sell us on a linuxcnc frontend is in IMO is not being very considerate of this group.
you shoudt consider the new linuxcnc 2.9 install and a use of o modern PC system then going to 2005 Technology outaged
- Thank you received: 5281
03 Jul 2019 00:05 #138469
Replied by PCW on topic Best video card for pathPilot
Actually 2.8 is current and 2.9 is master
- smgvbest
03 Jul 2019 00:16 #138471
by smgvbest
Where is it? are we talking source code only?
If I goto Linuxcnc.org it says
LinuxCNC 2.7.14 released
Jun 18, 2018
2.8 or 2.9 is not an option
Jun 18, 2018
- Vmax549
03 Jul 2019 00:25 #138472
by Vmax549
"The answer you got from tormach was posted several times in this forum, including by myself.. a search would of turned that up. but I for one did not understand what you where really after, you do not need a i7 3.4GHZ with 32G of ram for PP, most of that will go to waist, Tormach has stated that and posted in this forum."
I did do that search and did not see that answer . Can you list the discussion.
One thing I have learned after being in teh DIY CNC game for MANY years is MORE CPU, more Memory and GPU with plenty of memory allways make a better controller.
It has on every system I have worked with. BUT PathPilot may be the exception but I don't think so.
Just a thought , (
TP
Just a thought , (
03 Jul 2019 00:28 #138474
Yes the ISOs (and website information) are quite old. I also don't know what the buildbot is building...
But at least for a couple months 2.8 has been the release version and master is 2.9
Jun 18, 2018
- smgvbest
03 Jul 2019 00:29 #138475
by smgvbest
You are in a different world, those systems are not real time OS's. doing work in a guaranteed time slot is what's important here not how fast you can update a gui.
In gaming and other applications I would totally agree with you
but when your machine can do say 250IPM you simply don't need a fast machine most of the time to controller is waiting on the moves complete so the application is very different here.
- smgvbest
03 Jul 2019 00:32 #138476
by smgvbest
Ok, Thank you
Are the new gui's part of 2.9 or do I need to pull something else to see these things?
I do not know that I am in the mood to build LinuxCNC myself to play with new stuff so might be a long time before i see it in action
Jun 18, 2018
Ok, Thank you
Time to create page: 0.143 seconds
