- Thank you received: 51
PathPilot Screen freezes after idle for an hour.
7 years 3 months ago #140270
by smgvbest
Replied by smgvbest on topic PathPilot Screen freezes after idle for an hour.
This might be a thought but based on posts made you are not very Linux savvy. you stated above you had driver install issues. so my first guess is you're having driver issues causing the freeze. Perhaps your first course should be on a Linux forum and get the correct drivers installed for Linux Mint. (be sure it's the same version as PP or you can running into problems still)
After that, have you installed LinuxCNC on the computer using the same version of Linuxcnc that PP does? and gotten that to work? if not the first suggestion made here is to do that before jumping into PP.
Most users here go for hardware that is compatible with what Tormach uses. There are no special video drivers required. the boards used by Tormach tend to be Intel HD based for video. under V1 there was warning about certain chipsets causing problems due to USB issues. perhaps that's still true for V2, they recommended disabling USB3 ports on those chipsets. perhaps that's a problem you're having???
trying to help and really recommend getting your driver issues fixed and running LinuxCNC without issue before moving to PP.
7 years 3 months ago #140285
by Vmax549
Replied by Vmax549 on topic PathPilot Screen freezes after idle for an hour.
I do thak you for teh help you are very kind.
This MB is an tntel chipset MB it was bought based on teh Tormach specs. (
Asus mb Intel chipsets Intel gpu
i3 CPU @3.2ghz
8gb of ram
250gb SSD
2gb PCIex16 video card GT710 ( suggested by a linux Mint group).
TP
i3 CPU @3.2ghz
8gb of ram
250gb SSD
7 years 3 months ago #140287
That might case some issues, some Nvidia cards case latency spikes when changing internal frequencies going from one power mode to another.
I said "might" !
Replied by tommylight on topic PathPilot Screen freezes after idle for an hour.
Vmax549 wrote: 2gb PCIex16 video card GT710 ( suggested by a linux Mint group).
(TP
I said "might" !
7 years 3 months ago #140288
by Vmax549
It really depends on HOW teh appication uses teh Video driver. Testing with the installed driver made teh card work but was unstable. BUT if you hop out of PathPilot into Linux Mint it seems to work perfect. It never froze up there . I ran a test progam to test the video performance and it seemed FINE. But that was not the end of the story PathPilot was a different story.
I did test this combo with a W7 setup and another controller and did not have any problems so the hardware does work just not with Linux Mint / PathPilot.
I did run across an older Linux Guro that suggested this has always been teh case with Linux and hardware and he recommended a driver for Intel Chips that has always worked for him. I will try that driver to see if it works here.
7 years 3 months ago #140289
Does the motherboard have a built in graphic card ?
If it does, you should try it, usually that works better with Linuxcnc.
You can also enable software rendering and give it a try, you might be surprised. I know i was, but on a RPI3 !
7 years 3 months ago #140291
by Vmax549
Yes it does have a built in video BUT that would not work either and it only had teh open source driver from linux. I did try to update drivers for that BUT there was not another driver available through linux Mint.
So I went with teh GT710 video card. And there were only 2 drivers available 1 propietary and one open source.
It is not like I have not tried to make it work . It has just become a huge TIME vampire to do so.
I still have not figured out HOW to install a driver from USB or disk. It centainly is not obvious to me. I am limited to teh process inside of Linux Mint and it just checks a depository of drivers most of them are open source.
TP
Time to create page: 0.070 seconds
