Upgrade to PP 2.xx on Tormach 1100 series 1 from Mach 3
7 years 1 month ago #145531 by PCW
7 years 1 month ago #145534 by belli
I don't think PP was ever designed for parallel port. It started with the 5i25/6i25, hardware step generation is always better... ;-)
To set up PP for parallel port is a lot of work and for the cost of a 5i25/6i25/7i92 I just don't think it is worth it. The BOB hasn't really changed in all this time, I have checked the circuit diagrams and the changes are fairly small. The earliest I have is 30162 Rev5 which was basically their first BOB but I don't have the circuit diags for it. Before my time...
7 years 1 month ago #145536 by belli
I've had a look at the 'drive with pots on it', there is a single part number: 223-0462 Rev0.
I don't know who made it or what kind of drive it is but has 220/115V 1ph input and a 3ph output(U,V,W). The output stage is GB15B60KD IGBT's arraged in three half bridges. There is no micro that I can see but a 22V10 programmable logic chip.
It has an input for ENable, Direction and a Speed command (0-5V).
Perhaps someone here can shed some light on it.
7 years 1 month ago #145577 by andypugh
belli wrote: I don't think PP was ever designed for parallel port. It started with the 5i25/6i25, hardware step generation is always better... ;-)
Agreed. But if the original Mach3 was parallel port (And I really have no idea if that was actually the case) then a basic LinuxCNC installation (without PP) is trivial.
Then, with some fluency in LinuxCNC gained, it would be a case of merging the two configs to get PP working on the PP.
7 years 1 month ago #145613 by Ilikeapples
I just checked the bob, it is a 30162 ver 2.0 rev 0
7 years 1 month ago #145614 by Ilikeapples
The Mach 3 is parallel port
Time to create page: 0.116 seconds
