belli wrote: Hi Apples,
The upgrade to PP is definitely worth it. You could also try the raw LCNC but there are many features that you will miss (conversational programming), etc. Machines up to Serial 200 had the earliest BOB and didn't support some spindle speed features (there was no VFD in the box). The later ones were pretty much what they have now, the BOB design hasn't really changed.
So, questions:
What is the part number of your BOB?
Do you have the spindle upgrade (inverter)?
Are your stepper drives Leadshine or Prodrive (Gecko clones)?
I doubt that you will have any difficulty upgrading, your .ini might need a bit of tweaking but that is all.
Cheers,
Ilikeapples wrote:
belli wrote: My serial number is 325 built in 2007. I’ll have to look at the bob for part number when I get home Thursday, but it’s very large and doesn’t look like today’s bob’s. Definitely not leadshine steppers, and I’m not sure about the spindle upgrade but I doubt it. My VFD is a board with a bunch of pots on it. I bought the usb stick with 2.0 and put it on a Dell T5500. Now I think I need the 5i25 and then the 7i92? As far as the .ini goes, is it complicated to tweak? Thanks!
There is a reasonable chance that you can configure LinuxCNC / PathPilot to work with the existing hardware (if it doesn't already)
