andypugh wrote: Is there any sign of a Mach3 XML file? If there is then you could be up and running with LinuxCNC very quickly, as the "stepconf" wizard can import a Mach XML file.
Even if you don't plan to use the parallel port I think that this might be a useful exercise for the time it takes.
belli wrote:
PS Apples, post the .xb1 file It will offer enough info.
