- Thank you received: 907
Clive S wrote:
smgvbest wrote: Check out Tormachs site for thier probes.
here's the direct link to the page and doc
tormach.com/passive-probe-kit-32309.html
pdf here
tormach.com/media/asset/t/d/td10088_pass...be_install_0515a.pdf
last page has the pin-out
this is my opinion
grab the Tormach doc on anything you're trying to implement. they do a decent job of documenting things
Thanks. I had not seen that PDF
but I had the pin outs from the manual. But the tool setter I have has another switch lower down NC contacts I would like to put this switch in the estop chain or some other way of stopping the machine if the first one fails
any suggestions?
Clive S wrote: Yes I was thinking along those lines but I did nor want to keep the din plug in all the time. I suppose I could put a dummy plug in or a switch on the panel across the relay contacts.
Do you know what the voltage on the e-stop chain is and is it AC or DC
