Pathpilot plasma
- robertspark
- Thank you received: 216
18 Dec 2020 13:04 #192366
by robertspark
Pathpilot plasma was created by robertspark
does anyone know what Mesa hardware could be used for Pathpilot Plasma?
I was playing last night with the online PP SIM (nice!) and noticed they had a plasma cutter
I was looking at the promotional video at 1:18 it shows you the controls
looks like it is 2 boards
one for motion control and a second for THC and ohmic sense (on one of the setup clips it shows you the first run setup and how to set the ohmic probe up)
just curious if it could too run off a 7i92 as a near drop in and run (+ pin remap ) option?
yes I know about Plasmac, no this is not a measuring stick thread, just curious if it could be made to run as it looks like they may have contracted MESA for their custom I/o + voltage sense & ohmic PCBs.
just like the pp GUI.
thanks as always
thanks as always
- snowgoer540
- Thank you received: 907
18 Dec 2020 17:40 - 18 Dec 2020 17:41 #192410
by snowgoer540
Replied by snowgoer540 on topic Pathpilot plasma
They use a thcad-5.
You too would need that in addition to the Mesa card of your choosing 7i96 etc
Last edit: 18 Dec 2020 17:41 by snowgoer540.
- Thank you received: 4155
18 Dec 2020 21:11 #192417
Replied by rodw on topic Pathpilot plasma
Yes, the top board is recognisable as a THCAD. Thats been discussed before.
I thought I heard Tormach now used its own custom FGPA card instead of a Mesa card.
They could possibly do both Ohmic and torch voltage sensing with one THCAD.
- snowgoer540
18 Dec 2020 21:44 - 18 Dec 2020 21:46 #192419
by snowgoer540
When I peeped in the hal file, it had the appropriate references for a Thcad-5... don’t believe they’re doing any variation of “hypersensing”
Correct they do use custom FPGA cards.
My guess has always been that they work with Peter for them, though I’ve never had that confirmed...
Last edit: 18 Dec 2020 21:46 by snowgoer540.
- robertspark
18 Dec 2020 23:01 #192423
by robertspark
it looked like a wider thcad (custom?) with more pins available on the wiring connectors, thanks
Replied by robertspark on topic Pathpilot plasma
They use a thcad-5.
- snowgoer540
19 Dec 2020 07:16 #192450
by snowgoer540
Like I said they have custom looking stuff, I believe it's still done by Mesa, but I also know he open sources most of his stuff, so.. who knows.
Here's from the Plasma .hal file:
Thus leading me to believe its at least a variant of the THCAD-5
They use a thcad-5.
#Torch voltage
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.counter-mode true
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.scale 1
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.filter false
net rawtorchv hm2_[HOSTMOT2](BOARD).0.encoder.00.velocity scale.0.in
#Reading actual voltage
#5v calculation (half of the hv resistors shorted out)
#0v=96khz 5v=933khz
#0v to 5v = 837khz
#Gain = 5v/837000 hz =.00000597371/hz
#offset = .00000597371/hz * 96000hz * -1 = -.573476
# x50 gain = 0.0002986857
# x50 offset = -28.6738
setp scale.0.gain 0.0002986857
setp scale.0.offset -28.6738Thus leading me to believe its at least a variant of the THCAD-5
- snowgoer540
19 Dec 2020 07:25 #192451
by snowgoer540
and I'll leave the ohmic stuffs here too. Unfortunately, not using a second encoder so no commercial hypersensing...
# Ohmic touchoff input on J9-6 J9-7
# gpio 26
# Probe latch input 3
# setp hm2_[HOSTMOT2](BOARD).0.gpio.026.is_output 0
net probe2-in hm2_[HOSTMOT2](BOARD).0.gpio.026.in_not plasma-switch-debounce.2.in
# Probe input goes to an and2 which disables it when the torch is on
net probe2-debounced plasma-switch-debounce.2.out ohmic-touch-enable.in-00
# We route the torch-not-on signal into ohmic-debounce.0 to apply a delay to it after it turns off
net torch-not-on-signal torch-not-on.out ohmic-touch-enable.in-01 ohmic-debounce.0.in
net delayed-torch-not-on ohmic-debounce.0.out ohmic-touch-enable.in-03
net ohmic-touch-gui-enable ohmic-touch-enable.in-02
# Note: probe-latch input happens after the GUI disable for ohmic touch (so we can ignore it if needed)
net ohmic-touch-out ohmic-touch-enable.and torch-probe-or.in1 probe-latch.in-02
# Final touchoff probe hookup
# OR of the ohmic touch probe and the physical switch based one
net probe-input torch-probe-or.out motion.probe-input
##################################################Please Log in or Create an account to join the conversation.
19 Dec 2020 16:50 #192484
Actually, Robert has eagle eyes. It has 8 pins on the output side and the THCAD only has 6. I'm wondering if those extra wires are for ohmic sensing.
I think It's quite viable to use the one THCAD, for arc and ohmic sensing, particularly if you have a custom FGPA board.
Its also interesting to see they use the data structures I suggested way back in the Plasmac Development thread where I proposed a SQLlite database that allowed you to select a machine and retrieve the settings for it. Very cool.
- snowgoer540
19 Dec 2020 21:26 - 20 Dec 2020 06:31 #192500
by snowgoer540
Last edit: 20 Dec 2020 06:31 by snowgoer540. Reason: Fix pics
19 Dec 2020 22:17 #192503
If you trace the wire marked CAP back, that refers to the Ohmic CAP on the torch and the probe signal connects to the encoder pins that the Mesa Plasma bit file would call "encoder 2". So they can use the same board for other machines.
I wonder if their card includes the resistors we've been using? I guess they would.
I think they've quietly benefited from the open source development and put together a good package.
Time to create page: 0.263 seconds
