PathPilot V2 source code
4 years 7 months ago #236545 by smgvbest
Replied by smgvbest on topic PathPilot V2 source code
Yes.
gpg --yes --no-use-agent --decrypt --passphrase=moravianvalley --output=tgz_filename tgp_filename
tgz_filename is your compressed tar file name you want
tgp_filename is the file you want to decrypt
The following user(s) said Thank You: tommylight, robertspark, snowgoer540
4 years 7 months ago #236551 by snowgoer540
Thank you for saving me from rooting through the code :)
4 years 7 months ago #236555 by smgvbest
it was actually easy to find.
grep -Ri tgp ~tmc/python
its in
pathpilotmanager.py
4 years 7 months ago #236563 by automata
Replied by automata on topic PathPilot V2 source code
tormach.com/pathpilot-v20-upgrade-38249.html
Is this the right item to order?
Does this have the source code for the Liuxcnc pre-2.8 release that is going out with pathpilot 2.0 releases?
Will this require the gpg password alluded to later by smgvbest (gpg --yes --no-use-agent --decrypt --passphrase=moravianvalley --output=tgz_filename tgp_filename)? Password can change?
The shipping overseas is really killing...so I also will most likely use a mail forwarding service.
-automata
4 years 7 months ago - 4 years 7 months ago #236577 by smgvbest
No that is the version for running the machine it does not contain the source code
You want to contact Tormach customer service and request the PP2 Source code. they will tell you how to order which usually involves sending them a check for $10.
they will send you a CD with the source code.
it contains only the parts of LinuxCNC Tormach uses, not the full release of LinuxCNC. you can get the full release on the web.
the gpg password is only to decrypt the update files Tormach sends out if you want to look at them prior to installing them. you can run a diff on them vs your previous installed version to see what they changed.
if you want to build a working version of PP2 from source you're going to want a DEV version of it. I installed PP from the USB drive to a VMWare image first then installed the PP source to it. downloaded the LinuxCNC release they used for that part then you have to install a compiler and tools like glade if your want to edit screens, you also have to install all the dependencies.
in PPV1 source you could do a 'make dep' to install the dependencies. that was removed in PPV2 so you'll have to work those out to get a clean compile.
I would get it to compile cleanly with the original source first before making any changes to the source
Also FWIW,  Tormach uses WingIDE for python work and the source is built for it for debugging. For 'C' use your choice of IDE's or do by hand.
Last edit: 4 years 7 months ago by smgvbest.
4 years 7 months ago - 4 years 7 months ago #236599 by sagreen
Replied by sagreen on topic PathPilot V2 source code
@smgvbest
Over in another thread I recently posted a message about not being able to get compiled executables working that were compiled using 2.8.0-pre1 linuxcnc (the archive file you posted. thank you!) If you could take a look at this message, that would be a huge help.
forum.linuxcnc.org/pathpilot/34463-compi...use-with-pathpilot-2
Do you have to have all of tormach's source code as well to make the compiled executables work in Path Pilot? I thought you could compile 2.8.0-pre1 and just move the files over.
Thanks,
Scott...
Last edit: 4 years 7 months ago by sagreen.
Time to create page: 0.355 seconds
