THCAD-10 + hypertherm 45 (nonXP)
8 years 5 months ago #110483 by rodw
I have to agree with John. I have not had any problems either.
Why don't you comment out the part in your touch off that turns on the machine torch and waits for arcok and write a loop that calls it from the one X,Y position say 100 times and see if you run into problems. If you don't, it isn't a probing problem.
8 years 5 months ago #110490 by islander261
Guys
Actually I think the problem is related to to the part origin and how you are setting the Z zero when probing . I just don't have time to look into it this week. There are a couple of significant differences between how I do the touch off and how you are doing it. More details to follow the beginning of next week. If your problem is following error (FERROR) at the end of the cut then you really need to consider using the external offsets branch and tracking the Z position inside the motion component ( there is a real kludgey solution that I have figured out but haven't tested that is very similar to how this is handled in CommandCNC with external THC hardware if you don't want to use the external offsets branch).Think about how you handle machine and part positions on a milling machine (LCNC likes milling machines not plasma cutters).
John.
8 years 5 months ago #110493 by bjames28
Hello
Thanks all for the reply, I will raise this issue on SheetCam forum for sure.
@islander261: I agree with you, this should be more about how the probing is done and how the absolute& relative coordinates are put together. I just couldn't find out what exact line(s) of code should be written in different way. I'v reviewed and tried at least five touchoff routines posted on forums, but none of them seemed to solve the issue.
8 years 5 months ago #110560 by islander261
Guys
Here is what I am doing. First I use two coordinate systems. The machine coordinates set against homing switches at startup and second the work piece set as G54 offsets. In the mainline Gcode I move the torch to what I call the W height from what it is called on my mill, I think the more universal term is safe Z. Then I call my probe_sheet3 sub routine. Next is a simplified version without all of the error checking and retries.
o<simple_sub> sub M64 P0 (enable probing power supply, relay) F#<probe_rate> G38.3 Z-[#<probe_dist>] ( probe down to material surface) G91 G01 Z-.005 ( push down a little to insure good contact, float switch provides compliance) G90 M66 P3 L0 Q0 (check for source of probing signal, contact or float switch) o106 if[#5399 EQ 1] (probe was triggered by z-min so we need to add switch offset) #<probe_source_flag> = 1 o106 else #<probe_source_flag> = 0 o106 endif F [#<probe_rate>/16] G38.5 Z1 (raise torch until contact is lost) o107 if [#<probe_source_flag> EQ 1] o108 if[EXISTS[#<_ini[axis_z]float_sw_offset>]] G92 Z -[#<_ini[axis_z]float_sw_offset>] o108 else G92 Z -.06 o108 endif o107 else (set part Z 0) G92 Z 0.0000 o107 endif M65 P0 (disable plate sensing) o<simple_sub> endsub
I then take care of moving to pierce height and firing the torch in the mainline Gcode. I hope this helps with the probing problems. The attached file does have unexplainable (to me) problems displaying in Gremlin preview. The o<endcut> subroutine does nothing at this point, it is just a place holder left over from an external THC or not using the external offsets branch. I have cut several sheets out using this code so I know it works.
The attached Gcode file produces copyrighted parts so please respect my IP, it is how I eat. I am providing it as an example to the community of a complex file that works.
I will post the SheetCam PP that produced this code later when I am on my design machine.
8 years 5 months ago #110562 by islander261
Guys
Please find attached the SheetCam PP that produced the previous G code example. This is a work in progress so it will change.
8 years 5 months ago - 8 years 5 months ago #110571 by bjames28
Hi John,
Many thanks for the files you provided.
I went to the shop and quickly loaded the files to my plasma computer.
It worked!! (after some small tweaking, see my comments below). Now all cuts are on the same height level. Excellent. I had no time to analyze what do you do different, but in the evening Ill spend time on it.
I also installed the PP you sent.
There is one "inconsistency" with the multipleif..then..else nesting which originates from PP, and this caused an error when I wanted to load your gcode file to LinuxCNC. I found that one extra o010 else
Please find below the relevant part of gcode with added indents for better readability:
o020 if[ #<_firstTime> EQ 1 ] o010 if[ EXISTS[#<_hal[plasma_tab.use_control_params]>]] o011 if[#<_hal[plasma_tab.use_control_params]> EQ 1] o012 if[ EXISTS[#<_hal[plasma_tab.g0-gap]>]] #<_g0-gap> = #<_hal[plasma_tab.g0-gap]> o012 else #<_g0-gap> = 20.000 o012 endif o013 if[ EXISTS[#<_hal[plasma_tab.pierce-gap]>]] #<_pierce-gap> = #<_hal[plasma_tab.pierce-gap]> o013 else #<_pierce-gap> = 8.000 o013 endif o014 if[ EXISTS[#<_hal[plasma_tab.cut-gap]>]] #<_cut-gap> = #<_hal[plasma_tab.cut-gap]> o014 else #<_cut-gap> = 6.000 o014 endif o015 if[ EXISTS[#<_hal[plasma_tab.pierce-delay]>]] #<_pierce-delay> = #<_hal[plasma_tab.pierce-delay]> o015 else #<_pierce-delay> = 1.000 o015 endif o016 if[ EXISTS[#<_hal[plasma_tab.w-gap]>]] #<_w-gap> = #<_hal[plasma_tab.w-gap]> o016 else #<_w-gap> = 10.000 o016 endif ( __SUSPICIOUS extra line:__o010 else ) o011 else (Use values from SheetCam Below) #<_g0-gap> = 20.000 #<_pierce-gap> = 8.000 #<_cut-gap> = 6.000 #<_pierce-delay> = 1.000 #<_w-gap> = 10.000 o011 endif o010 endif #<_firstTime> = 0 o020 endif
I marked SUSPICIOUS the extra line.
I needed to create an empty endcut subroute, because there was a reference in your code. I don't know what is the purpose of this sub in your setup.
When I commented out the line 774 in PP file, the code is loadable without errors.
Thanks you very much for your help!
Regards
Janos
Last edit: 8 years 5 months ago by bjames28. Reason: correcting typo
Time to create page: 0.072 seconds
