CNC plazma Microstep - retrofit
- islander261
- Thank you received: 216
26 Mar 2018 03:04 #107884
by islander261
Replied by islander261 on topic CNC plazma Microstep - retrofit
r4cv
Attached you will find an archive of the configuration files for my plasma table. This is not production code! I have cut many test lines with it but no production work. I am sure there are errors buried in here someplace. Please do not use to run a machine, for information only.
- r4cv
26 Mar 2018 05:23 #107891
by r4cv
Replied by r4cv on topic CNC plazma Microstep - retrofit
Thanks. I´m going to study.
- r4cv
26 Mar 2018 18:48 #107907
by r4cv
I do not understand
Today I read those links. is described as how to make a variable from a G-code file to the system. this is in plasma.py
If I have the right idea, I need a system variable (in HAL file) into a G-code file (subroutine).
can you explain this to me as a fool?
my programming skills are poor.
- islander261
26 Mar 2018 20:09 #107911
by islander261
r4cv
Please give a full description of what you want to do. Please include any Hal pins already defined for the task. Sorry I am not a programmer either.
This may help:
linuxcnc.org/docs/devel/html/remap/remap...ap:referto-hal-items
You can also use M67 and M68 if you want to go from Gcode to Hal.
I am sure the code I posted has many examples of what you want to do in it. There are HAl pins set and read from Gcode and variables passed from the GUI to the HAL and Gcode. There is no escaping it, unless you want exactly what Tommy has posted, you will need to do some programming to get a custom plasma system running.
This may help:
- r4cv
29 Mar 2018 20:45 #108083
by r4cv
today's success
I managed to make remap G38, touch off and set start height from HAL pin.
Thanks to all of you.
Next step is finish remap, all necessary subroutines and resolve CAM (what and why).
Time to create page: 0.167 seconds
