THC Servo Start
- islander261
- Thank you received: 216
01 Jun 2018 18:19 #111403
by islander261
THC Servo Start was created by islander261
Hello
I have found some strange behavior when cutting that didn't show when I was testing with straight lines. The torch is making a small "divot" in the cut when the THC starts servoing after starting the cut and when it starts servoing again after a corner, velocity or kerf crossing hold. The "divot" is small and only visible from the bottom or side of the part. This is cutting 14ga ( about 2mm) hot rolled steel sheet at 220ipm at 45A. All the hold controls are done in HAL components so I don't think there is much delay happening. Sorry,I don't have any halscope plots of this happening because it is so hard to get the triggering right when cutting out a whole sheet of parts. I will start on a dedicated test at some point down the road that I can monitor with halscope.
- Thank you received: 7485
01 Jun 2018 21:47 #111415
Replied by tommylight on topic THC Servo Start
That is strange, if the THC servo is on the servo thread maximum delay should be about 0.1 to 0.2mm at that speed, i can not figure out why is that taking so long ( roughly guessing from the picture, over 1 second ). Can you test that on a straight line? Might that be because of the radius ( arc ) at the beginning and active corner lock ? Can you test it with corner lock disabled ?
Thank you.
Tom
Thank you.
Tom
- islander261
01 Jun 2018 22:02 #111417
by islander261
Replied by islander261 on topic THC Servo Start
Tommylight
Thank you for the reply. The point at which the THC starts servoing is correct. I have a about .75s delay between the arc ok or ok to move signal from the plasma power supply before the THC starts servoing. The marks from the corner hold being released are in about the correct place. I have not tested with no corner hold (I actually use a velocity hold instead of a hard distance) yet but expect to see no hold release mark when I do. I didn't have this happen when I did all my straight line testing while getting the THC working correctly.
- Thank you received: 5328
01 Jun 2018 22:02 #111418
Replied by PCW on topic THC Servo Start
How is the hold done?
If you have a PID loop with I term, you must disable the PID (say by tying its command and feedback inputs to the same value) when its not in control or you will get integral windup, causing a major glitch when you re-enable the control loop
- islander261
02 Jun 2018 01:07 #111426
by islander261
PCW
Thank you for the reply. I cause a height hold to happen by disabling (setting pid.enable to false) the THC pid component. I was under the impression that this reset the integrator. From the docs:
pid.N.enable bit in
When true, enables the PID calculations. When false, output is zero, and all internal integrators, etc, are reset.
I was counting on the docs being correct when I came up with this scheme for THC.
I am running the classic method for using Mesa stepper cards. I use the pid output as a velocity input to the 7I76E card step generator when under control of the THC logic just like when it is under command from the motion component for positioning.
pid.N.enable bit in
- islander261
02 Jun 2018 01:39 #111428
by islander261
PCW
Sorry I have two systems that do not have seamless integration. Please find attached a block diagram of my Z axis setup with THC.
02 Jun 2018 02:36 #111433
Yes, the PID integrator is reset by enable so that should be OK
It should be possible to trigger halscope on the edge of enable to check what's happening
- islander261
02 Jun 2018 03:50 #111438
by islander261
PCW
I had a very long winded reply that was killed by my poor typing skills. I know how to use a 'scope but it is really hard to pick the correct cut segments out of a 14,000 line gcode program. I plan on putting together some tests the mimic this problem as soon as I get time from production work. I never saw this problem during my all my straight line testing to get the THC working well. I am trying to transition my LinuxCNC control system to production work right now.
I love my Mesa cards and openly recommend them to anyone that wants to build their own CNC control. I do have the 7I76E and THCAD combination working really well for plasma cutting now except for this little divot thing (well at least better than my old commercial control system).
- Thank you received: 4149
02 Jun 2018 04:07 #111439
Don't you hate that? What Peter is saying is that you should be able to let Halscope sit there idling and it will trigger and start logging when the pid is enabled so it only starts logging when it has to.
Replied by rodw on topic THC Servo Start
- islander261
02 Jun 2018 04:17 #111440
by islander261
PCW
Yes, I understand how to use a 'scope. The problem only started showing up (or I noticed it) while I am transitioning my LinuxCNC control system to production use. So I am cutting on a sheet with 600 to 900 pierces or cut segments and I have to catch one of the problem segments while trying to watch out for any other major problems that may actually damage the machine. A bad torch crash can cost upwards of $300 in parts to repair even with a break away torch mount, don't ask how I know this. Hey I built this system from open source tools and I am not a professional machine tool builder or control system builder. While cutting at 220ipm things are happening very fast and it is hard to see details while looking out for serious damaging stuff. This is continuous cutting over an hour to an hour and a half period so keeping the concentration going while watching a boring (when it works correctly) process is a challenge.
I plan on setting up some controlled testing for this in the near future when I get a break in production. I also
Please don't get me wrong I love my Mesa hardware and recommend it to anyone after having a close source commercial system for years. With that equipment one was left to guess about problems and the support was always quick to blame you for not following their poor instructions instead of finding the real source of poor cutting, usually their software or hardware.
Time to create page: 0.401 seconds
