THCAD-10
22 Aug 2018 21:19 #116464 by BigJohnT
Replied by BigJohnT on topic THCAD-10
There is no problem with multiple hal files
linuxcnc.org/docs/2.7/html/config/ini-config.html#_hal_section
and for hal files the addf can sometimes be important what order you use
linuxcnc.org/docs/2.7/html/hal/basic-hal.html#_addf
JT
The following user(s) said Thank You: kb8wmc
  • kb8wmc
  • kb8wmc's Avatar Topic Author
  • Premium Member
  • Premium Member
28 Aug 2018 21:18 #116738 by kb8wmc
Replied by kb8wmc on topic THCAD-10
I am still having same problems with the THC working properly...
When attempting to perform cut with thc-pid active the machine goes through all the motions up to following the tool path...There it goes haywire...
I initialize the start arrow button with a tool path to be cut...The machine then properly performs a touch off, then moves to proper pierce height...The arc then starts and the torch moves to proper cut height, then almost immediately or upon first movement onto the tool path, the torch quickly raises and loses its arc...
I am just guessing but it seems to me that the THC is actually working, thereby causing the torch to raise to the point where the arc is lost...There is so little time between the events that I cannot get any useful data from the hal configuration... Another guess is that my THC settings are not properly tuned...The scale offset value is the only value that I am confident with as that value (118000) was taken from the sticker on the back of the THCAD-10...
Any input is welcome...Either I am not seeing something of settings are incorrect, or something that I do not even suspect...
Thanks in advance
Mike
  • Moderator
  • Moderator
28 Aug 2018 21:30 #116739 by tommylight
Replied by tommylight on topic THCAD-10
Wrong voltage setting, or more precisely you have it set to a value higher than the actual voltage so you keep getting lower voltage to the input forcing the torch to move up in an attempt to raise the voltage.
I can not get into more detail as i do not know how you have it set up.
28 Aug 2018 21:37 - 28 Aug 2018 21:43 #116741 by PCW
Replied by PCW on topic THCAD-10
When things are too fast to see, halscope will show you what is happening...
Other things to check:
Did you check the THCAD output voltage frequency or voltage (a 9V battery works here)
Note that the encoder scale sign must be right or the THCAD output in hal will have the wrong polarity (read negative)
The 118000 offset frequency only applies in 1X mode so if you use a THCAD divided mode you must scale this appropriately
Last edit: 28 Aug 2018 21:43 by PCW.
  • kb8wmc
  • Premium Member
  • Premium Member
28 Aug 2018 21:54 #116743 by kb8wmc
PCW...Any tips or relevant how to's for calculating the scale?
I have not checked the output voltage frequency...Can you point me in the right direction to a howto for doing this check?
Tommylight...I think I just learned something here from you on the actual voltage...
Thanks to you both
Mike
28 Aug 2018 22:06 #116744 by PCW
Can you post your existing hal/ini files?
  • kb8wmc
  • Premium Member
  • Premium Member
28 Aug 2018 22:40 #116746 by kb8wmc
PCW, sure can provide them...
The plasma.hal file is pretty much stripped down and contains mostly motion related data...The postgui contains mostly the pins and connections to the display panel...The thc.hal file is where most all of the THC related parts are...
Thanks in advance
28 Aug 2018 23:07 #116748 by PCW
I dont see that the encoder scale is set anywhere
If the thc-pid comp expects positive numbers and direct frequency inputs you probably need to set the encoder scale to -1
You can easily check if frequency is positive with halmeter
  • kb8wmc
  • Premium Member
  • Premium Member
28 Aug 2018 23:22 #116749 by kb8wmc
I am back at home right now PCW...I will have to get back at it tomorrow...
I have followed JT's setup pretty much to the "T" or so I believe, and I believe JT developed the thc-pid component, so I am making the assumption that all is as it should be with his component...I don't know what to do or say about setting the encoder scale as I see no reference to it in JT's files, unless I just don't recognize it...
thanks bunches PCW
Mike
  • kb8wmc
  • Premium Member
  • Premium Member
29 Aug 2018 16:40 #116788 by kb8wmc
PCW, I have re-read the THCAD-10 pdf manual several times now and have some questions...
In the calibration section, if I comprehend this correctly, the output frequency at 0V is given from the sticker on back of THCAD-10 card (118,000 = FZERO)...The output frequency for 10V is also provided on card (924,000 = FFS)...In the given formula FZERO is subtracted from FFS providing a resultant (806,000)...
I am only assuming that VFS has in this case the value of 10...
Now it gets fuzzy to me in that within the encoder setup portion of the thc.hal file, I have the "scale offset" as 118,000...My present opinion is that I am incorrect as to the use of what I have set as the "scale offset" number...
Again, I make an assumption, that FOUT is somehow arrived at by using a 9V battery on the input side of the THCAD-10 but I am uncertain...I am not electrical guru but I can follow simple instructions...What I read on the pdf is not clear to me...
Any guidance would be appreciated and I am sure I will have more questions...
Mike
Time to create page: 0.318 seconds
