thefabricator03 wrote: I have not had time yet to play with RodW's new hypersensing design but it should have some ability to tune the reading voltage to overcome some of the false readings.
Floating head will work if you have finer slats under it, it will work anyway you look at it, but it will need some help from you with thin material.The_wolf_of_walmart wrote: Ok I can definitely see why floating head is bad for thinner materials. Why is ohmic bad for thicker materials?
tommylight wrote: Ohmic is better at sensing thin materials but it is less reliable than floating switch/head.
rodw wrote: But what I've found is that Plasmac recovers so perfectly I don't stress about it.
