- Thank you received: 11
snugglylovemuffin wrote: WILL MY PROMA WORK ON HF START?
[Just a bit of wiring practice and question about specific components. Obviously question marks will show what I don't quite understand how to wire up. I'm not running an encoder on my Z axis, so I think a few of these commands are superfluous for my application.
WILL MY PROMA WORK ON HF START? YES
THCUD connections found @: linuxcnc.org/docs/ja/html/man/man9/thcud.9.html YES
thcud.torch-up bit in = pin 10 (hm2_7i96.0.gpio.010.in) YES
thcud.torch-down bit in = pin 9 YES
thcud.current-vel float in = Connect to motion.current-vel ???????????????? YES
thcud.requested-vel float in = Connect to motion.requested-vel ?? YES
Float switch (pin 7)?? = motion.probe−input
thcud.torch-on bit in= Connect to motion.spindle-on ????????? Usually
thcud.arc-ok bit in = pin 8 YES
thcud.enable bit in = Enable the THC, if not enabled Z position is passed through ?????????YES
thcud.z-pos-in float in = Z Motor Position Command in from axis.n.motor-pos-cmd ?????????YES
thcud.z-pos-out float out = Z Motor Position Command Out pid.z.command
thcud.z-fb-out float out = Z Position Feedback to Axis YES
thcud.cur-offset float out = The Current Offset
thcud.vel-status bit out = When the THC thinks we are at requested speed
thcud.removing-offset bit out = Pin for testing
/quote]
