Yo men,
Your switch offset in your ini is problably at zero. (home offset value... use -5mm for example and try it.)
Try one of this :
#HOME_LATCH_VEL = -1
#HOME_SEARCH_VEL = -20
#HOME_FINAL_VEL = -1
#HOME_IGNORE_LIMITS = YES
#HOME_OFFSET = -2
#HOME_SEQUENCE = -2
HOME_LATCH_VEL = 0
HOME_SEARCH_VEL = 0
HOME_FINAL_VEL = 0
HOME_OFFSET = 0
HOME_SEQUENCE = 0
So homing sequence -2 is mostly used for 2 motors on x axis together. (-2 is not -2mm... !!!! IT IS
A HOMING SEQUENCE.... not my favority solution. but is works.)
if you use -3 for y and -4 for z. It wil do this axis for axis homing procedure. Takes very long time.
Home sequence 0 = oke without homing.
So a good option when you are at production scale. To have multiple linuxcnc start desktop pictogram's.
One for homing and one for no_homing. The you are master dude.
To the programmers. The Homing procedure documentation is a mess, even Gmocappy struggles with this issue.
So i don't struggle with this, I made a c component for homing. And it is all solved.
