Snuggly's Plasma Build
7 years 10 months ago #122323 by islander261
Replied by islander261 on topic Snuggly's Plasma Build
Use the configuration files I posted on Monday! The ones you just posted are old files that will not allow homing of the Z axis and have some other problems with inconsistent and illogical values in the .ini.
The following user(s) said Thank You: snugglylovemuffin
7 years 10 months ago #122335 by snugglylovemuffin
@rodw: I noticed that, which made it all the more confusing. I just went through all my wiring when I cleaned up my box, I'll check it again just to be sure.
@Islander261: I wanted to isolate the issues and deal with one variable at a time before changing up the files. I'll try them out right now.
Update in a few
7 years 10 months ago #122385 by snugglylovemuffin
@Islander261: here is the launch error
hm2/hm2_7i96.0: invalid token in config string: "num_ssrs=1"
hm2/hm2_eth: rtapi_app_main: Invalid argument (-22)
7 years 10 months ago #122386 by rodw
Replied by rodw on topic Snuggly's Plasma Build
snugglylovemuffin wrote: @Islander261: here is the launch error
Thats what can happen when somebody writes something for you and does not have your hardware. All you need to do is to locate the line in John's config starting with
loadrt hm2_eth
And replace it with the same line in your working config
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=0 num_pwmgens=0 num_stepgens=4"
7 years 10 months ago #122387 by snugglylovemuffin
Got it, that's what I did last time. I'll try it again and see how she chooches.
7 years 10 months ago #122388 by islander261
Sorry, I misunderstood the hostmot2 documentation about requiring enumeration of solid state relay outputs. Do as Rod said. Also you will need to comment out or delete this line:
setp hm2_7i96.0.ssr.0.rate 1000000
