Snuggly's Plasma Build
7 years 9 months ago #124003 by snugglylovemuffin
I know, just had them wired without power.
My entire TB3 output and common are all switching on and off; this clearly isn't a HAL or physical wiring issue. I'm wondering if somehow the board is faulty.
PCW, if you'd like to weigh in here; I have not even entertained the notion of messing with EEPROM
7 years 9 months ago #124004 by PCW
Replied by PCW on topic Snuggly's Plasma Build
If the input common is switching you probably have a wiring or power supply issue
7 years 9 months ago - 7 years 9 months ago #124006 by snugglylovemuffin
Isolated inputs are working properly. It's just the outputs that aren't working properly by switching on/off. I've pulled wiring and it doesn't seem to make a difference. I'll check my PSU, however wouldn't my inputs be switching too if it was my psu?
Last edit: 7 years 9 months ago by snugglylovemuffin.
7 years 9 months ago - 7 years 9 months ago #124009 by PCW
Are the hal pins for the outputs changing?
7I96 isolated output hal pins are:
hm2_7i96.0.ssr.00.out-00
hm2_7i96.0.ssr.00.out-01
hm2_7i96.0.ssr.00.out-02
hm2_7i96.0.ssr.00.out-03
hm2_7i96.0.ssr.00.out-04
hm2_7i96.0.ssr.00.out-05
Last edit: 7 years 9 months ago by PCW.
The following user(s) said Thank You: snugglylovemuffin
7 years 9 months ago #124015 by snugglylovemuffin
No, it's just the common pin. I erroneously read the GPIO instead of the SSR thread, my mistake. Power supply seems to be fine, but I'll try hooking it up to an isolated power supply just in case. It really is bugging me, there's no reason for it to be doing this. If hooking it up to a power supply doesn't work, does that mean the firmware is corrupted?
7 years 9 months ago #124028 by PCW
Not sure what you mean by the "common pin" (the outputs are individually isolated)
Firmware cannot really get corrupted and still load ( The FPGA checks the firmware when its loaded and will detect any changes from the valid original image )
If you have wired one side of all the outputs to a power supply pin (your output common) and this output common is not stable relative to the other power supply
pin, this is not something the 7I96 has any control over.
Time to create page: 0.234 seconds
