THCAD-10
- Thank you received: 4144
06 Apr 2019 11:27 #130391
Replied by rodw on topic THCAD-10
We'll be here to help. John can take the day shift and Phill and I down under will do the night shift
- Thank you received: 7466
07 Apr 2019 23:43 #130456
Replied by tommylight on topic THCAD-10
I'll be watching from the stands ! Currently doing some cleaning and modifications to the workshop, it was a mess !
08 Apr 2019 00:04 #130458
Hmm, forgot about your time zone. Looks like we need to run 3 shifts!
- Dee436
- Thank you received: 13
08 Apr 2019 00:09 #130459
by Dee436
Replied by Dee436 on topic THCAD-10
Ok
I have a run in place plasmac alongside my 2.7 installation. It is late here in the UK so unable to go any further tonight. I can start the sims in the various gui’s and they look great, although my current drivers limit my monitor to 1024x768 so I am having to scroll a bit to see all the details.
Not sure what the next step is in order for me to be able to use this as a live solution.
Darren
Darren
- phillc54
- Thank you received: 2100
08 Apr 2019 07:13 #130484
by phillc54
Copy your existing working hal and ini files into the above directory.
Open the ???_plasmac.ini file and copy any of the required sections/settings to your inifile.
Open the plasmac.hal file and make necessary changes.
Run linuxcnc like:
$ ~/your_git_directory/scripts/linuxcnc ~/linuxcnc/configs/your_config_directory/your_ini_file.ini
Hopefully you will be up and running. (assuming I haven't forgotten something...)
Cheers, Phill
Replied by phillc54 on topic THCAD-10
Copy the sim config files and subdirectories you want to use to a directory in your ~/linuxcnc directory.Dee436 wrote:
Run linuxcnc like:
Cheers, Phill
- Dee436
08 Apr 2019 08:25 #130486
by Dee436
Thanks Phill
Will try it this evening.
What you have put together looks really good.
Darren
Darren
- islander261
- Thank you received: 216
08 Apr 2019 14:48 #130519
by islander261
Replied by islander261 on topic THCAD-10
Dee
If you have trouble post your current working .ini and .hal files here. Also post the full path you are trying to install the configuration AND the full path to the plasmac sim you ran. I have just done this recently but will be off island for the middle of the week.
Get your Z working first followed by any single drive axis and finally any dual drive axis.
09 Apr 2019 01:24 #130535
It is 3:23 AM here, does that count as the third shift ?
- Dee436
14 Apr 2019 21:07 #130873
by Dee436
I appreciate the offers of help on this, but unfortunately due to work I have not had the chance to spend anymore time looking at this. I am hoping to get a couple of hours this coming week to try get the configs done and see how it goes.
- islander261
14 Apr 2019 22:21 #130877
by islander261
Time to create page: 0.123 seconds
