Bob's Plasmac Build
7 years 5 months ago #134920 by bevins
Bob's Plasmac Build was created by bevins
Here we go. Lots of stuff ordered and awaiting receipt of.
Table completed.
7 years 5 months ago #134930 by tommylight
Replied by tommylight on topic Bob's Plasmac Build
Hey Bev,
that is for the plasma you are building right ?
You should add some cross members to make the table more rigid in the middle as if cutting thicker steel plates it will buckle in the middle with time.
7 years 5 months ago - 7 years 5 months ago #134982 by pl7i92
Replied by pl7i92 on topic Bob's Plasmac Build
whow
it seams he plans on 2inch thick sheets
this may break the shop bottom if it is finished within that support
Will it be a Watertable or only airfree plasma
I hope you made Air Holes into the frame as the air is supposed to flow inside the bars
otherwise it will bend SOON and make it a unusable THC master pice
Last edit: 7 years 5 months ago by pl7i92.
7 years 5 months ago #134986 by rodw
Replied by rodw on topic Bob's Plasmac Build
Looking good Bob.
7 years 5 months ago #134990 by bevins
Replied by bevins on topic Bob's Plasmac Build
Yeah I have some holes for air. And it will have a water table. Ac servos and Plasmac.........
I am using unistrut cross members. Support should be fine.If required I can add some.I did design triangular support but customer didnt want to pay for it.
  • thefabricator03
  • New Member
  • New Member
7 years 5 months ago #134993 by thefabricator03
Replied by thefabricator03 on topic Bob's Plasmac Build
Looks Good,
It will be interesting to see how you are going to design the slat holders and the water tray. I take it that it will sit on top of the frame rather than sit in the frame.
Time to create page: 0.329 seconds
