Bob's Plasmac Build
7 years 1 month ago - 7 years 1 month ago #144123 by rodw
Replied by rodw on topic Bob's Plasmac Build
Very nice Bob. It almost looks like you know what you are doing! :)
Which is a lot more than I can say about me when I built mine!
Last edit: 7 years 1 month ago by rodw.
The following user(s) said Thank You: bevins
  • thefabricator03
  • New Member
  • New Member
7 years 1 month ago #144133 by thefabricator03
Replied by thefabricator03 on topic Bob's Plasmac Build
I can say the same thing about when I built mine as well. I had not really seen many CNC plasma machines before and I had never used one, Lots of google image searching!!
Bob, Is this machine for a customer or yourself?
7 years 1 month ago #144139 by rodw
Stefan, it makes me feel better now!
It would actually be interesting to know what your gantry ends weigh with the motors mounted. They are a bit like the folded Ally ones I made and from memory they weighed about 7kg (15.4 lb) each.
I think my total gantry with ends weighed about 34 kg (75 lb) so its not that much difference to what you expect. If I did it again, I'd only use one HGR15 rail on the X axis as 2 was overkill and added more weight than what was needed.
7 years 1 month ago #144145 by bevins
Replied by bevins on topic Bob's Plasmac Build
This is for a customer.
7 years 1 month ago #144146 by bevins
rodw wrote: Stefan, it makes me feel better now!
I think it will weigh in around 100 lbs maybe.
Still thinking on how to do the X bearings and Rack and Pinion. The bearings will have to be on two separate sides because it is only 2" X 4" alu extrusion. Rack and pinion on top maybe. Not sure yet. I should have put 3" X 6", but that stuff is triple the price.
7 years 1 month ago #144150 by rodw
bevins wrote:
rodw wrote: Still thinking on how to do the X bearings and Rack and Pinion. The bearings will have to be on two separate sides because it is only 2" X 4" alu extrusion. Rack and pinion on top maybe. Not sure yet. I should have put 3" X 6", but that stuff is triple the price.
I know the feeling. It was all a bit of a puzzle. I Went through so many iterations.
I got mine to fit on an 80mm x 40mm extrusion so you have plenty of room. When you say bearings, you mean linear bearings and rails? If you look at the radial torque specs of the HGR rails, you only need one rail (even for HGR15...) Provided you are not wanting to use it as a router!... Clive's looked nice with a rear mounted motor...
Time to create page: 0.487 seconds
