Bob's Plasmac Build
5 years 11 months ago #190050 by bevins
Replied by bevins on topic Bob's Plasmac Build
Is there an issue if I mount the THCAD in a box on the machine and run the encoder inputs to the mesa card?
That way I can keep the high voltage out of the control panel. Would it need to be shielded and it is about 20 feet maybe 15.
5 years 11 months ago #190053 by PCW
Replied by PCW on topic Bob's Plasmac Build
Yes this is fine, just make sure that the cable shield is only connected at the control box
end (and that the THCAD is powered via the "encoder" cable)
5 years 11 months ago #190062 by bevins
PCW wrote: Yes this is fine, just make sure that the cable shield is only connected at the control box
OK great.
I am using 7i76, Can I use the enc0 for thcad and enc1 for mpg?
5 years 11 months ago #190063 by PCW
You would use the high speed encoder (TB3 pins 7 through 14) for the THCAD
and the Field I/O connection for the MPG(s) (TB5 pins 1,2,3,4)
The following user(s) said Thank You: bevins
Time to create page: 0.066 seconds
