Bob's Plasmac Build
6 years 11 months ago #151281 by rodw
Replied by rodw on topic Bob's Plasmac Build
Here Bob, A couple of DXF's for you to mount THCADS on a DIN rail (single and double). Looks like you might need them.
Designed to use a Meanwell metal Din Rail mount.
File Name: drive-down...-001.zip
File Size:8.62 KB
6 years 11 months ago #151290 by bevins
Replied by bevins on topic Bob's Plasmac Build
tommylight wrote: You got 3 of them ! :woohoo:
Looking nice.
I already have a thcad. I am working on two plasmas.
6 years 11 months ago #151291 by bevins
rodw wrote: Here Bob, A couple of DXF's for you to mount THCADS on a DIN rail (single and double). Looks like you might need them.
File Size:8.62 KB
I bought din rail mounts from JT..... I'll take a look at them though.
6 years 11 months ago #151293 by rodw
Yeh but the THCAD has a different pitch between holes so JT's mounts won't work with the THCAD...Hence my plasma cuttable templates but heck I'm sure you can make do with a router for now! I used 1.6mm Ally sheet metal.
6 years 11 months ago #151294 by bevins
He has some specific for the thcad.
6 years 11 months ago - 6 years 11 months ago #151490 by rodw
It seems the difference between JT's and my DXF is that his is very expensive in terms of the DIN rail they use.
If you cut the mount and used one of those clips to mount the plate, you would run the THCAD perpendicular with the rail
This layout makes more sense to me.
Last edit: 6 years 11 months ago by rodw.
Time to create page: 0.076 seconds
