Bob's Plasmac Build
7 years 1 month ago - 7 years 1 month ago #144155 by bevins
Replied by bevins on topic Bob's Plasmac Build
rodw wrote:
bevins wrote:
rodw wrote: Still thinking on how to do the X bearings and Rack and Pinion. The bearings will have to be on two separate sides because it is only 2" X 4" alu extrusion. Rack and pinion on top maybe. Not sure yet. I should have put 3" X 6", but that stuff is triple the price.
I know the feeling. It was all a bit of a puzzle. I Went through so many iterations.
I got mine to fit on an 80mm x 40mm extrusion so you have plenty of room. When you say bearings, you mean linear bearings and rails? If you look at the radial torque specs of the HGR rails, you only need one rail (even for HGR15...) Provided you are not wanting to use it as a router!... Clive's looked nice with a rear mounted motor...
You have a link to Clive's?
\/Edit Never mind, I found it.
Last edit: 7 years 1 month ago by bevins.
  • thefabricator03
  • New Member
  • New Member
7 years 1 month ago #144214 by thefabricator03
Replied by thefabricator03 on topic Bob's Plasmac Build
bevins wrote:
This is for a customer.
I am sure they will be really happy with it.
7 years 1 month ago #144440 by bevins
A little bit of fab work....
7 years 1 month ago #144441 by bevins
The following user(s) said Thank You: tommylight, thefabricator03
7 years 1 month ago #145639 by bevins
Just winging it.....
7 years 1 month ago - 7 years 1 month ago #145640 by bevins
Time to create page: 0.177 seconds
