What is Plasmac?
- thefabricator03
- Visitor
06 Jun 2019 01:13 #135994
by thefabricator03
What is Plasmac? was created by thefabricator03
Hi Guys,
I have been testing out the Sims of Gmoccapy and Axis and what I have come to realise is I do not like how they are set up.
My question is what exactly is Plasmac? I know it is a component that Phill has created, What makes it different to other plasma linuxcnc setups what were made before it?
What I would like to do is get my head around how the system works then I will hire a developer to design a new user interface base on QT.
I plan to in the future sell complete plasma cutting tables so I need a user friendly interface to include with my tables.
- Thank you received: 7488
06 Jun 2019 02:00 #135998
Replied by tommylight on topic What is Plasmac?
I do not think I can help much as I use only Axis with the THC_toma config. It is fully automated and easy for clients to learn and use, so it ended up being used every day on a lot of machines built or retrofitted. Now I am reluctant to change anything as it never fails, and that makes clients very happy.
Personally I did try the plasmac and it was magnificent for functionality and it run Axis, so for me all boxes were ticked. I will use it for testing for sure on my machine.
The difference is that it has everything ( and more ) needed for a fully fledged CNC Plasma Cutter, like setting the feed rate depending on the thickness of the material you chose on the menu, reverse run, very smooth THC control when coupled with Mesa THCAD, etc.
The list is long so it would be better if Phill or/and others can chime in.
- Thank you received: 4151
06 Jun 2019 02:05 #135999
Replied by rodw on topic What is Plasmac?
In my head, plasmac is 3 components:
1. Patched version of LinuxCNC to include reverse Run
2. Plasmac.comp - a real time THC component
3. The GUI, the remapping and python extensions Phill has built that has become bigger than Ben Hur.
What Sets Plasmac apart from things that have gone before is no gcode probing routines, PID based torch height control and use of external offsets so it only needs X-Y gcode. Plus the GUI sophistication and included cutting rules. Phill has basically rolled up all of the stuff others have done over the last couple of years into one cohesive unit.
I would keep to the script and only modify the GUI as in time I expect plasmac will end up in the core code so it will be much easier to maintain the system for you. I would look at working with these guys to build a plasma specific screen forum.linuxcnc.org/41-guis/34996-another...ect-underway?start=0
The following user(s) said Thank You: thefabricator03, jay1st
- thefabricator03
- Visitor
06 Jun 2019 02:44 #136001
by thefabricator03
Thanks Rod,
I will read through that thread tonight.
This might be a very basic question but how does linuxcnc work with components? I take it that there is a core code and the components add on to it.
I would gather that the GUI is just a front end that interacts with the core code and components?
Replied by thefabricator03 on topic What is Plasmac?
Thanks Rod,
06 Jun 2019 03:31 #136003
When you loadrt a component, you are loading an object file in to memory
When you addf a component, you are adding that to a particular thread, Usually the servo_thread
Lets just talk about the servo_thread for a moment.
LinuxCNC calls this thread 1000 times per second. Each component that has been loadrt'ed is called in turn so components need to be short sharp and sweet so that everything gets done before the next call. If it doesn't then latency is exceeded an an error is reported.
Components are written in a variant of C and are compiled and installed with halcompile. hlacompile wraps the necessary complex C headers around the source code and compiles to object code (executable code, like a DLL in windows). Optionally halcompile will install it which just copies it to the correct folder in LinuxCNC so it can be found.
eg.
will compile and install my_comp.comp
If you are not using run in place, you need to use sudo so you give halcompile the rights to work in system directories.
This is Linuxcnc's best kept secret as you can add stuff to the environment yourself and it acts as if its part of the base config.
See
linuxcnc.org/docs/devel/html/hal/comp.html
Most hal components are very short and sharp. Plasmac is huge by comparison. The other option is to create multiple components that are joined together to do the same job piece by piece. I favour this approach as it compartmentalises each function from errors in other sections of the code. This is also more consistent with the LinuxCNC paradigm. But it does come at the cost of more complexity in Hal.
The other option suggested by Andy is to rewrite the task and io modules which are also loaded in the ini file to be plasma specific. This is something I'd like to explore if I had the time.
eg.
halcompile -- install my_comp.compwill compile and install my_comp.comp
See
- AgentWD40
- Thank you received: 96
06 Jun 2019 03:41 #136005
by AgentWD40
Replied by AgentWD40 on topic What is Plasmac?
Here is a very cool/functional gui that @BigJohnT is working on: forum.linuxcnc.org/41-guis/36506-qtpyvcp-plasma-gui
- phillc54
- Thank you received: 2100
06 Jun 2019 22:43 #136118
by phillc54
Cheers, Phill.
Replied by phillc54 on topic What is Plasmac?
plasmac is a monster that is taking over my life.My question is what exactly is Plasmac?
Cheers, Phill.
The following user(s) said Thank You: rodw, thefabricator03
06 Jun 2019 22:46 #136120
Me thinks you over thinking dis! Or......
I also like having things clearly separated as you do, but sometimes for some things that is just not possible. Luckily Linuxcnc can do that for most things, but not all.
- phillc54
07 Jun 2019 01:11 #136145
by phillc54
Tom,
I think the main problem is that I don't know enough about plasma cutting so I rely on what others say and I often misinterpret what was said.
My total experience is 4 or 5 hand cuts about 100mm long...
But I am having fun and that is the main thing (well it is for me anyhow)
Cheers, Phill.
Cheers, Phill.
- islander261
- Thank you received: 216
07 Jun 2019 03:57 #136164
by islander261
Replied by islander261 on topic What is Plasmac?
Phill
Cut two sheets today with your latest release. Total success, 100% yield. Reverse run saved two parts that errored out because of tip ups that cause torch break away errors. Had an error while in IHS skip distance, it appeared to recover OK. The plasmac probing is so fast I may have missed it, busy look at the big picture to notice the ohmic led.
