Updated to Master Branch, Stuck in E-Stop
- Uthayne
- Thank you received: 49
15 Jul 2019 02:18 #139358
by Uthayne
Replied by Uthayne on topic Updated to Master Branch, Stuck in E-Stop
No, I did not figure it out. Perhaps it was just time for a fresh install anyway.
Table is back up and running and working great!
photos.app.goo.gl/14kc5BWsZBLryM3N6
The following user(s) said Thank You: phillc54, rodw
- phillc54
- Thank you received: 2100
15 Jul 2019 02:24 #139360
by phillc54
Replied by phillc54 on topic Updated to Master Branch, Stuck in E-Stop
Glad to hear it, that looks cool...No, I did not figure it out. Perhaps it was just time for a fresh install anyway.
The following user(s) said Thank You: jschulze
16 Jul 2019 12:06 #139552
It doesn't really matter, all the amp-enable pins toggle at the same time, there is actually no point having one per axis.
Replied by andypugh on topic Updated to Master Branch, Stuck in E-Stop
Is this a gantry machine? If so, its set up as wrong for 2.8/2.9
net emcmot.02.enable <= joint.2.amp-enable-out net emcmot.02.enable => hm2_5i25.0.stepgen.03.enable hm2_5i25.0.stepgen.04.enable
Why does joint 2 connect to stepgens 3 & 4?
Time to create page: 0.092 seconds
