Air Scribe with PlasmaC
10 Aug 2019 01:58 #141839 by rodw
Replied by rodw on topic Air Scribe with PlasmaC
Edit: You could still use M5 for the end of both as that will stop all spindles.
Yes, I was going to say once a spindle was set, the $n on F5 was optional.
  • thefabricator03
  • thefabricator03's Avatar Topic Author
  • Visitor
  • Visitor
10 Aug 2019 02:18 - 10 Aug 2019 02:19 #141840 by thefabricator03
Replied by thefabricator03 on topic Air Scribe with PlasmaC
This is where I dont really understand, If we are using multiple spindles does that mean that the G-code commands for the plasma torch wont apply if we have spindle 1 selected? Do we have to define spindle 0 as the plasma torch or is it already set up?
Well my take on this is that each spindle has its own spindle.n.on signal and we use spindle 0 to trigger the torch (using spindle.0.on)
We are currently treating our machines as single spindle machines. But I think if you did gcode like this (and I'm no expert with gcode)
(set a spindle speed on all spindles to keep Linuxcnc happy)
S100 $0
S100 $1
(Cut something)
T1 M6 (select plasma tool - x, y offsets  = 0,0)
M3 $0 (use plasma)
...( cut some stuff)
M5 $0
Go x1,y1 (go somewhere else)
M3 $0 (use plasma and enable plasmac via spindle.0.on)
...( cut some more stuff)
M5 $0
(Engrave something)
T2 M6 (select scribe and set offsets and enable scribe via spindle.1.on)
M3 $1 (use engraver)
.... (engrave some stuff)
M5 $1
G0 x2,y2 (go somewhere else)
.... (engrave some more stuff)
M5 $1
When you see how clean that code is, it does not really make sense to muddy it by adding a second signal to lower the torch. Sure that might happen but it should be done behind the scenes they way Plasmac does it. Plus you could have a whole row of tools up there. I did see Grotius post a pic with a drill bolted onto his gantry once.
Ok I understand now, So what do I need to set up to give it a go? I take it I need to write some kind of code for the post processor in sheetcam to spit out the correct G-code.
Do we need to define the Spindle0 as the plasma torch in PlasmaC? or hal/ini? And spindle1 as air scribe.
Also where do I set up the parameters for spindle1, As in turn on certain outputs to activate scribe relays, I take it that that is done in the Hal? I would like to set up that the scribe lower setting is turned on then after X amount of time the scribe it turned on then motion starts. I am assuming this also done in the Hal.
Last edit: 10 Aug 2019 02:19 by thefabricator03.
10 Aug 2019 02:38 - 10 Aug 2019 02:39 #141841 by rodw
Well its all automatically supported and stays out of the way until its used as I showed so there is nothing really to do other than hook spindle.1.on to your output.
Code will not run until spindle.1.at-speed is set true. I would connect a spindle.1.on to whatever solenoid needs to come on first and use a delay component to trigger the next one. You may need to chain to a second delay to give the scribe to get to the surface before triggering spindle.1.at-speed.. Let me know how you want it to work and I can be a bit more specific.
Last edit: 10 Aug 2019 02:39 by rodw.
10 Aug 2019 02:53 #141842 by rodw
Maybe sometihng like this.
loadrt timedelay
addf timedelay.0 servo-thread
setp timedelay.0.delay-on 0.5
net spindle-1-on  <= spindle.1.on
net spindle-1-on => my_7i76e-lower-output
net spindle-1-on => timedelay.0.in
net delayout <= timedelay.0.out
net delayout => my_7i76e-scribeon-output
net delayout => spindle.1.at-speed
  • thefabricator03
  • Visitor
  • Visitor
10 Aug 2019 02:58 - 10 Aug 2019 02:58 #141843 by thefabricator03
loadrt timedelay
Thanks Rod, That looks like it should do what I need.
Now the fun part, Modifying the post processor. I now realise that the code I posted earlier is for Mach3 not Linuxcnc,
Would I be better off trying to modify my CandCNC post for this task?
Last edit: 10 Aug 2019 02:58 by thefabricator03.
10 Aug 2019 08:10 #141849 by rodw
Stefan, I had thought once we know how we are going to do it, I might have a go at adding it to my POST seeing you are using it.
It should just be changes to the onPenDown and onPenUp methods as thats where the M3 and M5's are issued.
I did not get very far today. I went up to the shed to play with the ohmic sensing and decided I needed to upgrade to the latest version of master branch and after that, homing is not working on the X axis. Its just ignoring the home switch and plowing right through until it hits a limit switch. I think that must be a regression in master branch as all the signals were correct. If you email me the POST you are using I might get a chance to look at it over the weekend.
The following user(s) said Thank You: thefabricator03, RNJFAB
Time to create page: 0.242 seconds
