rodw wrote:
The hypersensing method we've devised (which thefabricator03 is not yet using) seems to have solved the problem and its in use by quite a few now on several different brands of machines.
Yes.stivemaster13 wrote: tommylight, maybe I don't understand something. You mean that you regulate with PID a simple stepper motor Nema17 with 1500-2000 rpm?
tommylight wrote: BTW i did push it to 68m/m but it started tearing the belts.
Does it?rodw wrote: Plasmac does something similar to what you suggest with the 12 volt threshold
There is a thc disable pin that has been available since June 2019I have asked Phill to add a seperate THC hold pin to Plasmac for third party use but so far he has been unwilling to do so. That would make extensions like this much easier to implement.
Would have to be very high quality ones, with rack and pinion the self induced vibrations might cause issues.thefabricator03 wrote:
If you were to use rack and pinion and a quality planetary gearbox, do you think it would handle those speeds well and be reliable?
