- Thank you received: 5
rodw wrote:
stivemaster13 wrote: I can not understand you ? What does it take 2 seconds? What I have written takes a maximum of 40 ms at the UCCNC. On Mach3 it takes 50ms.
This trick works even on our transformer sources, to which we have added an interruption of the cooling cycle, which generally lasts 15 seconds!
The hypersensing method we've devised (which thefabricator03 is not yet using) seems to have solved the problem and its in use by quite a few now on several different brands of machines.
stivemaster13 wrote: I have another question - does anyone have observations (ie the graph of the voltage change) that PlasmaC (or actually THCAD) sees when the burner touches the material during cutting? And is this being handled in any way, like an emergency?
I ask in terms of what I went through while developing our THC.
When I first started with plasma and linuxcnc before Plasmac, I did lot of halscope plots and had the torch hit the material many times. I don't recall observing any behaviour that was measurable. I did collect a lot of data and analysed it statistically. For that particular machine I measured 7.53 volts per mm of height. At 1.75mm cut height, I guess it wold hit the table on a fall of about 13 volts.
With Plasmac it has never hit the table.
You could disable downward height adjustments if the torch voltage fell by say 7-10 volts from the original sample. That would let the torch rise to cut height if it sorted itself out.
Yes it does !snowgoer540 wrote: Plasmac currently pauses motion if the float switch is activated during a cut.
