- Thank you received: 4153
tommylight wrote: Hmmmm that is new to me, thank you PCW.
I was under the impressions that the probing is switched off before firing the torch.
Adding a relay will solve that issue.
Now i have to wonder, if the probing THCAD is on all the time, the use of another THCAD seems redundant.
Will think about it a bit, while waiting for my THCAD's to arrive.
I know there has been a lot of discussion at times about "false" triggering of ohmic sensing. I can say with certainty that I have never had a problem with this that was a true false trigger. Yes, I have probing errors all the time but they are always caused by a flooded torch end or dross stuck in the torch end. So the probing errors are always cause by a true shorted torch which is why you check for that condition before the start of probing..
phillc54 wrote: An interesting quote from John in this post
tommylight wrote: Water is not a software issue, and there is nothing in software to fix that.
I'm pretty sure that is why John made you add the probe test button to the GUI so he could check for a shorted torch before running a job. Press the button and if the ohmic light came on, he had a problem.
