- Thank you received: 4153
phillc54 wrote: Yes, accurate and consistent probing is what we should be looking for, who cares if you save some milliseconds per probe. I would think that comparators would also be with a look. Do you know what John uses, he seems to have reasonably consistent results.
tommylight wrote: Well i think i was silent long enough about this...
Find a 1KOhm resistor at 1W ( or 2x 2.2K @0.5W, or 4x 4.7K @0.25W, in parallel ), and attach it to the THCAD5 input, that should make all your water problems go away. It is to sensitive and that is very good, but not when water is involved. That will make it require more current passing through the system to trigger ( or change measured values in this case )
470Ohm/2W should do even better, just a bit over 5 mA going through it.
