None of that around here, we use plain hard water from the surroundingrodw wrote:
tommylight wrote: Water is not a software issue, and there is nothing in software to fix that.
Tommy what about softwater instead of software????
Ohmic sensing does not work on a water table with a Plasmacam despite what people say. The water continuously goes back into the nozzle and shorts it out causing a "torch hit material" error. The machine continues to blow air after it is done cutting and this causes water to spray up into the torch, shorting it out.
thefabricator03 wrote: So your saying to a delay before the torch moves down to allow the water to blow out?
